how do these numbers look?
Old Oct 3, 2015 | 05:03 PM
sudsmcduff's Avatar
sudsmcduff
2 videos.. one of freeway 65mph at about 1800rpm and one of slow roll on at quarter to half throttle. thanks for any help. just replaced all hpop orings. i am in dp tune 60hp tow. stock gives code1211 all the time
Old Oct 3, 2015 | 05:09 PM
jhl3's Avatar
jhl3
I saw a FIPW of 3.44 but I could not tell what else was going on. Is the 3.44 justifiable? If so, why?
Can you have someone else hold the camera and hold it far enough away that it captures all of the data that is available?
Old Oct 3, 2015 | 05:12 PM
sudsmcduff's Avatar
sudsmcduff
Yea sorry about the shaking. Next time will have someone hold it. I don't know enough to understand these readings
jhl3's Avatar
jhl3
Then a 3224 ICP but I could not read IPRDC.
Old Oct 3, 2015 | 05:18 PM
jhl3's Avatar
jhl3
If that -40* is in fact Water temp could you replace that with something else, especially if you have a 4R100.
Old Oct 3, 2015 | 07:11 PM
sudsmcduff's Avatar
sudsmcduff
So the icp is off?
Old Oct 3, 2015 | 07:50 PM
Tugly's Avatar
Tugly
Yep... not WOT. It looks like you hit very close to the sweet spot on throttle - maybe just a tiny bit more can be given. I know this test very well. How did it feel? Have you been able to time your 0-60 MPH with this method?
Your IPR landed at 44% with 3200 PSI ICP - bingo on my self-proclaimed "High Pressure Oil Index". It looks real good for your HPOP and injector O-rings.
Old Oct 4, 2015 | 01:21 PM
sudsmcduff's Avatar
sudsmcduff
Truck feels better then it has in years. I never timed 0-60mph. I'm too scared to hold it that long floored. But I will go now and try again at wot. Glad the hpop is good. Didn't want to have to pull it off again
Old Oct 4, 2015 | 02:06 PM
sudsmcduff's Avatar
sudsmcduff
So my ipr hit 53.29 at wot
Old Oct 4, 2015 | 02:14 PM
glockholiday's Avatar
glockholiday
Side note. There's an X Gauge to install to make your scangauge read ECT engine coolant temp. Instead of the -40
Old Oct 4, 2015 | 04:07 PM
sudsmcduff's Avatar
sudsmcduff
Thanks. I will look into it
Old Oct 5, 2015 | 04:22 PM
sudsmcduff's Avatar
sudsmcduff
I'm just bumping this up. Not sure if ipr needs to be replaced?
Old Oct 5, 2015 | 06:49 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
IPR/ICP numbers look fine, no worries. 65% IPR is generally considered max, you're not even close. Why replace a good IPR?
Turbo sounds nice too.
Old Oct 5, 2015 | 07:07 PM
sudsmcduff's Avatar
sudsmcduff
Ok so 65% is what a new ipr number should be
Old Oct 6, 2015 | 07:25 AM
Tugly's Avatar
Tugly
65% is max when starting, or when things go wrong while running. The reason the tuning keeps IPR down to 65% max is to prevent huge ICP spikes when you let off the throttle ("Stinky Spikes"). Some tuners allow the IPR to climb to 100% IPR, but I personally don't agree with this tactic. If the IPR has to go that high in an attempt to reach the target ICP, something is amiss.
Look at the 44% IPR to get 3200 PSI ICP. At WOT with 160/100s and a T500, I reach 3000 PSI ICP at 42% IPR. These are all very good numbers... but a bit overwhelming to follow if you aren't fluent in 7.3L-speak.
Same truck, same day:
Aggie_Ford
Texas Chapter
36
Jul 6, 2016 11:30 AM
pnj442
Aug 26, 2010 06:26 PM
papadelogan
35
Apr 9, 2009 06:16 AM
leforrest
Sep 17, 2006 12:03 AM
cbfomoco
Jan 17, 2006 11:04 PM
