I have a 1986 F150 Lariat with an inline 6. When i drive the vehicle it heats up really quickly. If i turn on the vent or the heater I am able to maintain the temperature so that it does not over heat. Once the vehicle is turned off it takes a long time to cool. My question is is this is Thermostat / Water pump issue? I have looked into both and am honestly looking to just replace both of them. However, I cant find a blown up diagram in my Chilton's or any other literature that has the thermostat in it. Am I just missing it or am I completely off base. Any diagnosis suggestions or ideas on where to look are appreciated.
If the upper radiator hose does not become very hot to the touch and feel pressurized when the engine has warmed up fully, this suggests the thermostat may be stuck closed. That is an easy fix.
Or alternatively: coolant level may be very low, or pump went bad, or clogged radiator.
The gauge as well as temp taken straight from the engine compartment. It could honestly be scale and sludge. It is an 86 with 103000 miles on it. I bought it this spring.
