Driveshaft installation question
Old Oct 1, 2015 | 09:25 AM
whisler's Avatar
whisler
Due to severe frame rust, I'm transplanting my "84 351W engine, C-6 transmission and NP-208 transfer case and drive shafts into another 4x4. I know that I should have marked the yokes of both drive shafts at the transfer case but didn't (I know, stupid). I'm not sure how effective that would have been, in any case, since original front and rear differentials are not being used.
With all that said, what can I do now to eliminate balance problems with the drive shafts. Is it as simple as taking them to a shop and having them balanced individually? Are there other options? Trial and error doesn't seem like a good idea but this is the first time I have had to address this problem.
Any and all information and suggestions welcome (except "don't do that again"- I have already marked that one down).
Old Oct 1, 2015 | 11:43 AM
Nothing Special's Avatar
Nothing Special
Having the driveshafts balanced individually is generally the best way to go. I'm not sure I've ever even heard of them being balanced on the vehicle. Personally I've never bothered doing anything to make sure I got a driveshaft back in the same orientation it was, and I've never noticed any vibration issues.
The main thing to keep straight is that the yokes on both ends of the driveshaft need to be lined up with each other. If you pull the slip joint apart and put it back together off a spline or two you'll have a vibration you can't get rid of, even with everything perfectly balanced.
Old Oct 1, 2015 | 12:19 PM
Franklin2's Avatar
Franklin2
The only thing you have to worry about is the yoke alignment. Don't worry about the balance. When you put the splines together, make sure the yokes on each end line up. If you never disengaged the splines then they are probably ok but double check them anyway.
Old Oct 1, 2015 | 12:46 PM
whisler's Avatar
whisler
The drive shafts were taken out but not taken apart at the splines so it looks like I am good. Thanks very much for the replies.
JohnBOV43159
13
Jun 8, 2014 10:27 AM
77F-150
Nov 19, 2011 07:56 AM
77F-150
May 31, 2011 03:35 AM
user 528629
Mar 3, 2011 08:41 PM
GregN
Mar 30, 2010 12:10 PM
