M5od replacement
Agreed, you name it, I've done it and then some with the Mazda trans. I've neutral dropped it, bang shifted, missed gears, whooped some butt and hauled close to 1200 pounds of metal with this trans and other than the shift forks are giving me trouble now with shifting it's still Mint. What do you people do to these things? Do you load up a truck full of wood and then try and do a burnout with it? Because I just don't get how people break them. Not ragging on you by any means OP I'm just that curious.
My issues are most likely due to the PO. It looks like someone has been in it before because of the silicone gooped around the tail housing. It leaks and shifts relatively poorly. Even after replacing the shifter bushings it has gotten sloppy again. I blame the PO because I found the leaf springs on both sides broken in half. Also I wish 1st gear was lower.
To OP: I'm taking out an M5OD and putting in C-6 in my 89 F250 4X4 so I may have some measurements that will help. The M5OD without transfer case is 29 1/2 inches long; with BW 1345 transfer case total length is 47 inches. Distance from the front of the transmission to the center of the cross-member is 25 inches.
My C-6 measurements may not help because it is an '84 transmission and they changed the transfer case adapter length in later years. My transmission length without TC is approx. 26 inches. Maybe someone can tell you the difference in length of TC adapter for later years.
I'm using a Hurst Pro-Matic shifter with the truck length handle for gear change duties so everything will still be on the floor.
My M5OD gave me no trouble but my age and left knee condition prompted the swap. Also I had an '84 4x4 with a good motor and transmission and rusted frame, so the decision was fairly easy.
My M5OD is on craigslist right now but no bites yet.
on
For what it's worth I realize it's my fault it's warped but it's the third transmission I've had in the truck and it's at 330,000
kyflaresideon20s
10-10-2011 07:49 PM
