Lets talk about IFS.......
Old Oct 7, 2015 | 04:53 PM
  #31
1957460's Avatar
1957460
No my 460 has a steering pump and you just connect that to the rack on the crown vic ifs
Old Oct 7, 2015 | 04:56 PM
  #32
ultraranger's Avatar
ultraranger
Originally Posted by HIO Silver
Your steering shaft connects via couplings to the CV steering rack.. the PS pump connects to the PS rack. Or, you could probably get a manual rack like drag racers do for new model Mustangs.
All the '03-up Crown Vic, Mercury Grand Marquis, Mercury Marauder and Lincoln Town Cars had power R&P. I'm not sure that there's a manual rack available for this application (?).
If not, it isn't a good idea to run a power rack without hydraulic pressure being applied to it.
Old Oct 7, 2015 | 05:21 PM
  #33
itsabullitt's Avatar
itsabullitt
Aftermarket companies make non power R&P for the Mustangs of that era. I'm not 100% sure if it would be a direct replacement for the Crown Vic, though.
Old Oct 7, 2015 | 05:48 PM
  #34
ultraranger
Good chance the MII R&P unit (from a smaller '74-'78 Mustang) will be narrower than a CV R&P unit from a much wider '03-up Crown Victoria.
It doesn't hurt to investigate it but, these will probably be the findings. Mounting points of the unit may not be the same either.
Old Oct 7, 2015 | 06:01 PM
  #35
HIO Silver's Avatar
HIO Silver
Yeah, dunno either. That's for the CV'ers to find out!
Old Oct 7, 2015 | 06:25 PM
  #36
ultraranger
Early-on, after I bought my truck, I had visions of installing an '03-up CV front suspension and a T-Bird Super Coupe IRS. I even went so far as to buy each of these items (an '03 civilian CV front suspension and a '90 T-Bird SC IRS W/Traction-Lok 3.27 gears).
As time went on though, I couldn't bring myself to cut up my Ranger's frame. If it was just a base model or a Custom, it might have been different. I went with a (power) disc brake front suspension from a '77 F100, instead --and I added power steering.
Old Dec 18, 2015 | 03:51 PM
  #37
1957460's Avatar
1957460
How Wide of tires on flareside?
I have 296/50/15 on the back of my 57' right now but I am curious as to if anyone has went wider. I am pretty sure that I can fit 315's but I'd first like to see if anyone had first hand knowledge.
Old Dec 19, 2015 | 07:30 AM
  #38
crazed87bronco's Avatar
crazed87bronco
You could always try measuring to see if them 315's fit. Summit racing sells a kool tool that will bolt on to your axle and you can adjust it to any size to replicate the rim/tire size of your choice. That way you can make sure they fit and have clearance enough before you buy the rims and tires and find out the hard way.
Renner68
Jul 30, 2019 05:30 PM
bphirt1
Mar 19, 2018 03:03 PM
emeraldcoupe
Jun 16, 2016 07:35 PM
Hickfied
Jan 28, 2010 10:34 PM
83shotbed4x4
Feb 20, 2004 03:05 PM
