Are the frame stands for the motor mounts the same in 87-96 F150's as the 250/350's? What about motor mounts? I have a set of 460 swap motor mounts that bolt directly to the frame stands in 67-79 Ford trucks, and they are listed to also fit 80-96 250 and 350 trucks. My main question is, Why would they not work for F150s? If you can pull a 302 with motor mounts out of a 250 and drop it in a 150... Why can't you do the same with the 460?
becuase i think the frame mounts for the small block and big block are different.. i did a inline six to a V8 swap 5.0 and i used frame mounts for a 351 (5.8)
My swap mounts are listed to fit all 250's and 350's... they came with anything from a 4.9 to a 7.5.
