I know this is probably not the right place to post this, but I've got a question about a fuel issue that on my 67 International.
When I was driving the truck today it started running really rough, got home and shut the motor off and it will not start, not even a bump. Check to make sure I was getting fuel and noticed gas was running out of the carb housing.
I've got an elec fuel pump, so it will pump-up but will not shut off, just keeps pumping till the carb is full and then runs (leaks) out everywhere. Checked my fuel regulator and even replaced it, but that's not the problem.
My question is, once the FP has pressured up, what's suppose to turn it off? is there a valve or something inside the carb that's allowing fuel to pass through and flood the carb?
