Okay I have a 78 fwd f150. Has a 429 out of a 69 tbird.the truck has sat for a while and then I bought it. It had a 2 barrel carb on it so I swapped it back over to a 4 barrel. I noticed when I would try to crank is it would sorta lug getting started and once did. It didn't sound very healthy. So I did a full tune up since it hasn't had one from the 90s. I also advanced the timing a hair. It Cranks up, idles nicely, sounds good, pulls and drives just fine. Sometimes when cutting off though it would keep trying to stay started for a few seconds. Then shut off. I may have that fixed now but when the truck warms up and I shut it off and go to turn it back on it lugs like it doesn't want to start then after it sits for a few minutes it fires right up. Bad starter? Carb out of tune? Carb getting to much gas/air? Loose ground? Please help
It's either a bad starter or too much initial timing. To tell the diff, next time it doesn't want to start, pull the coil wire off and see if it will then spin over fine. If so, timing. If not, starter.
