Premium once a month?
Old Sep 27, 2015 | 07:07 PM
CapeMay609's Avatar
CapeMay609
Exclamation Premium once a month?
Hey guys, I have a 2006 Ford F-150 lariat, I always get regular gasoline, but I heard that once in a while it's good to throw a few bucks towards getting premium, is is true? And why?
Old Sep 27, 2015 | 07:43 PM
03f15012's Avatar
03f15012
Not really. Unless you've tuned it, putting premium is wasting money. The only real difference with gas is if you put in E85 (worse mileage), or 0% ethanol.
Old Sep 28, 2015 | 07:02 PM
1saxman's Avatar
1saxman
I've taken to using mid-grade sometimes, especially from the 'first tier' stations like Shell. This is to get the better additive package of the premium for $.30 less. I guess you know that mid-grade is mixed right there at the pump out of Premium and Regular. I found on recent trips that any of our vehicles get better mileage on it. Modern engine control computers have the ability to increase ignition advance for better efficiency based on information from the 'knock sensor'. Since 89 octane will stand more advance without knocking, you could actually see a little more power, which would be reflected by better mileage at a given speed since it would require slightly less throttle.
Whatever, I see a difference so I use it sometimes, particularly now that gas is cheaper.
Old Sep 29, 2015 | 08:05 AM
bbender85's Avatar
bbender85
Originally Posted by 1saxman
..Modern engine control computers have the ability to increase ignition advance for better efficiency based on information from the 'knock sensor'. Since 89 octane will stand more advance without knocking, you could actually see a little more power, which would be reflected by better mileage at a given speed since it would require slightly less throttle.
this reminds me of a theory (more a question maybe) i've had in my head for some time now about E85; i know it is higher octane, and i'm curious if would relieve or worsen my VCT issue i'm having at low rpms with the advanced timing from the higher octane. i'm not excited about the stuff so i haven't tried, but i wonder. i understand the efficiency loss of E85, i'm talking purely the driveability issue of my VCT-related shake at idle.
Old Oct 1, 2015 | 10:57 AM
YoGeorge's Avatar
YoGeorge
Top tier gasolines are given this classification because ALL their grades of gas have a high end additive package. In Detroit, top tier brands include Shell, Mobil, BP, and even Costco which I use. Costco states that their regular gas has 5 times the amount of detergent that is minimally required. So if you use top tier gas, there should be no reason to run premium for the detergent content.
George
Old Oct 1, 2015 | 08:50 PM
steve(ill)'s Avatar
steve(ill)
if you want to do something to help, make sure you use 10% ethanol every now and then. In Illinois that's your only choice. The ethanol will clean valves and injectors and never need anything else.
Old Oct 1, 2015 | 09:30 PM
thzpcs's Avatar
thzpcs
There's literally no difference between the lowest and the highest tier of gas other than octane. It's definitely better to get gas from a Top-Tier station, as they use lots of detergents and other additives that make their gas of a higher quality, but use whatever octane the manual says.
As for bbender's question, it's possible that E-85 could solve your issue. It has a decently high octane (100-110), but has a very low energy/mass compared to pure gasoline. A lot of people with heavily tuned cars run it, and can see significant performance gains from it if tuned for it.
Bugzilla46310
6.2L V8
16
Oct 10, 2016 06:33 PM
shammoofressh
2009 - 2014 F150
May 11, 2009 10:03 PM
Danger_Dave
Jun 13, 2007 12:11 AM
monkey nutz
Mar 13, 2006 09:51 AM
nj2003F150Buff
1997 - 2003 F150
Sep 13, 2004 06:06 PM
