What's this? and does it affect shifting?
Old Sep 26, 2015 | 01:40 PM
bart f-350's Avatar
bart f-350
Hello,
What is this piece called? (see pic) when my engine runs idle, my tach indicates 0, and if I start driving the tach indicates (almost) correct.
Also I wonder if this affects shifting?
7,3L IDI- E4OD
And, where can I get a new one? (not living in the USA)
What's the name of the piece with the two wires attached in the yellow circle?
Old Sep 26, 2015 | 01:50 PM
bashby's Avatar
bashby
Tach sensor. It will effect shifting on an e4od
Old Sep 26, 2015 | 03:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
ford part # E5TZ-17B384-A
here is one on evilbay for $68.88 and free shipping: http://www.ebay.com/itm/Ford-6-9L-7-3L-Diesel-Tachometer-Tach-Sensor-F250-F350-E250-E350-FSD-IDI-OEM-NEW-/201237302469?hash=item2edaad8cc5&vxp=mtrford parts giant for $60.70 : E5TZ-17B384-A - Genuine Ford SENSOR ASY
amazon.com for $67.90 :
Amazon.com: Ford E5TZ-17B384-A - SENSOR ASY: Automotive Amazon.com: Ford E5TZ-17B384-A - SENSOR ASY: Automotive
auto parts nation for $56.58 : SENSOR ASY | Genuine Ford | E5TZ-17B384-A
Old Sep 28, 2015 | 02:48 PM
bart f-350's Avatar
bart f-350
Thanks Tom,
I bought one, eta okt 16
I hope it brings better shifting, It should! (for 101$ with transport and tax)
Old Nov 27, 2015 | 01:16 PM
bart f-350's Avatar
bart f-350
Well, I drove a bit since installing this sensor, and it is different than before, like day and night!!
Thanks again TJC Transport~!!!!
Old Nov 27, 2015 | 01:37 PM
tjc transport
i ain't rite
no problem!!
glad you were able to get it over there and installed working condition.
that is the one thing that stinks about being in Europe, parts for our vehicles cost you twice as much as they do here.
Old Nov 27, 2015 | 03:31 PM
Fixnstuff's Avatar
Fixnstuff
Originally Posted by tjc transport
no problem!!
If I may ask a related question? OOPS, I should have posted this as a separate question for anyone reading this rather than a reply - too late now.
I have a C6 so this would not affect shifting, but my Tach reads about 100 RPM with the engine shut off. The sensor has been unplugged for a week while I'm doing some work in the engine compartment and right now the tach is reading about 50-60 RPM. I subtracted the difference when I used my tach to set engine idle speeds.
Is this error a function of the tach sensor or can the tachometer itself be correctly re-calibrated?
Thanks in advance.
Old Nov 27, 2015 | 04:03 PM
tjc transport
i ain't rite
never messed with calibration so i really cant say.
i don't even know how accurate mine is, i never really pay attention to the tach anyway
Old Nov 27, 2015 | 05:24 PM
mg94mg94's Avatar
mg94mg94
Thanks in advance.
The tachometer recieves a small electric signal from the sensor that tells it how far to move (Think analogue voltmeter or ammeter, or a sending unit). If your tach is not at zero when the truck is off, it has nothing to do with the sensor.
I'm not sure how the position motor (I dont know the proper term) connects to the needle, but if you want to fix it, you would likely have to take the gauge itself apart. (Perhaps there is a gear train, and a tooth jumped? Maybe the needle's shaft has moved within the position motor?).
texas7816
Aug 24, 2015 12:28 PM
broncrider051990
Jul 9, 2013 02:21 PM
31 swfl
Nov 24, 2009 11:50 PM
94_IDI
Sep 9, 2008 11:23 PM
davelong667
Mar 11, 2007 07:41 AM
