Does anyone know what front axle is in the 1966 f100 4x4? I can't find any ID numbers stamped on the housing. It appears to have a Dana 44 cover but has king pins upper and lower with open knuckle hubs. The king pins are plates held in place with four bolts.
Thanks for the info - any suggestions for parts for overhaul?
QUAD4x4.com out in Montana, very knowledgable source, got everything I needed from them to rebuild my 64 Dana 44 closed knuckle. You being in GA, try EastCoastGear. Enjoy!
.... to rebuild my 64 Dana 44 closed knuckle..... Enjoy!
1) Am I correct to assume that the 'closed knuckle' style of DANA 44 is vastly different from the '66/'71 type of DANA 44?
2) Are their mounting points/etc. the same between the types, i.e., can they be easily swapped?
3) Which type/style of DANA 44 do you believe to be better/stronger?
edit: Well, I think this answers my earlier questions: "The standard-duty Dana-Spicer Model 44 axle, which has 8 Bolt Knuckle Ball Seals, was used for all F-100 4x4s from 1959 to 1966, and for light duty F-250 3/4 ton trucks from 1959 through 1975. In 1961, an optional, Heavy-Duty version of the Dana-Spicer 44 front axles with 12 bolt Ball Seals was offered for the F-250. Ford F-100 Closed Knuckle axles were replaced by a King Pin type open knuckle Dana 44 front axle during the 1966 model year. Ford continued to use standard duty Model 44 closed knuckle axles right through the 1975 model year on light duty F-250 4x4 trucks. Ford was the last U.S. vehicle manufacturer to use closed knuckle axles on 3/4 ton models. For 1976, all Ford F-250 4x4 trucks would have either an open knuckle Dana 44 (Regular Cab) or Dana 60 (Crew Cab)." - QUAD4X4.COM
BarnieTrk
Hi BarnieTrk - It really is a difficult question to answer and depends more on what you are doing with the truck, what "strength" of axle you are looking for. For a daily driver where you use the 4 wheel drive occasionally for snow or mud, as long as the axle is well maintained theres no point in going for a "stronger" or the "strongest" axle. If you are in the woods and hauling loads, using 4X4 frequently, plowing snow is another axle devastator. - you would want a stronger axle. So, Ford gave an option for a HD Dana 44 back in the 60's with those scenarios in mind. Once you move up to the Dana 60 front axle (late 70's), that is as good as it gets for strength in a stock axle -IMO. Hope that helps.
I don't own a FORD 4X4 (I do own a rusty-n-trusty '95 Wrangler), so I am just trying to brush up on my FORD 4X4 knowledge of them a bit.
Around these parts, I am surrounded by GM 4X4 fans!
