Pre-Winter Maintenance 2015
Old Sep 21, 2015 | 08:22 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It's that time of year again when you should get those repairs you've put on the back burner done before the dead of winter sets in and you're making the repairs you should've done while the weather was good in the bitter and unforgiving cold.
On the list for my 7.3:
-Tie Rods
-Ball joints (not needed, but may do them for the heck of it)
-Wheel bearings
-Shocks
-Dual Steering Stabilizers
I may find a few other things, but the only thing that's going to cost me money are the stabs since they're not under warranty at the auto parts store like everything else.
What's on your list?
Old Sep 21, 2015 | 08:47 AM
HKusp's Avatar
HKusp
Front springs (with the new leveling kit) and sway bar bushings. Limp through the winter like that, then hopefully make enough money to get down to Lead Hill Arkansas for that BTS I have always wanted...
Old Sep 21, 2015 | 08:57 AM
nlemerise's Avatar
nlemerise
Disconnect the batteries, put on float charger, head to Mexico for cerveza, margaritas, and camarones!
Old Sep 21, 2015 | 10:56 AM
jgilrfr's Avatar
jgilrfr
NOW thats a plan,its not in my future but that would be nice
Old Sep 21, 2015 | 12:17 PM
binuya's Avatar
binuya
One simple item I've been forgetting to do the past couple years, especially since they're 6 years old now, is to check/top off the battery cells and clean up the posts and clamps. They're still cranking strong, but I've done neither of the above since I got 'em.
Old Sep 21, 2015 | 05:44 PM
Dave in Maine's Avatar
Dave in Maine
['03 F250 Lariat, 4X4, auto]
As a newbie, keeping it simple -bought some DieselKleen in the silver (watching the forecasts), an early oil change w T6, and keep an eye out for new and interesting leaks and problems during this shakedown period.
Old Sep 21, 2015 | 06:45 PM
FiznUKa's Avatar
FiznUKa
Top of the list for those of us that deal with freezing temperatures is making sure the batteries and glow plug system is in tip top shape. Nothin like changing a GPR in 0 degree weather. A must have is a GPR led light to know when and how long the glow plugs are on.
Old Sep 21, 2015 | 06:52 PM
Tedster9's Avatar
Tedster9
An equalizing charge is a good plan with a full size charger, too. It's actually hot weather that deteriorates batteries, cold weather just exposes it.
Old Sep 21, 2015 | 07:29 PM
enormiss's Avatar
enormiss
Fix a diesel leak that only happens in cold weather
Rebuilt drain valve last winter but that didnt cure it (summer did)
Old Sep 21, 2015 | 07:35 PM
Jaime74656's Avatar
Jaime74656
Well for me it time to install quick connect pieces for both batteries so i can hook the tender too, as for the GPR led, do we have any type of writing for it??? I assume it will connect to the relay in some sort of fashion?
Old Sep 21, 2015 | 07:36 PM
Pikachu's Avatar
Pikachu
Yeah, I hear those Houston winters are just brutal!
Old Sep 21, 2015 | 08:15 PM
Tedster9's Avatar
Tedster9
Two Tee-shirt weather? Brr!
Old Sep 21, 2015 | 08:26 PM
Sous's Avatar
Sous
FTE Emeritus
1. up pipes
2. blank pedestal
3. upgraded waste gate
4. high flow outlet
5. 6/6 turbo wheel
6. FRx
7. HPx
8. 360 thrust
9. rebuild turbo
I am sure I am missing something from my list, but you get the idea.
Old Sep 21, 2015 | 08:30 PM
Thomas White's Avatar
Thomas White
For the Group:
Glow Plugs
ESOF
Wheel Bearings
Brakes
Anti-Freeze
Old Sep 21, 2015 | 08:40 PM
FiznUKa's Avatar
FiznUKa
The LED mod is simple just find a small 12v led light the size of a pencil eraser whatever color you like and install it where you can see it when you turn the key most people will put theirs in the gauge pillar that's where mine is and run a 2-way wire to the GPR relay one to ground and the other to the big lug that is only hot when the glow plugs are on. If you have the glow plug module I can't help ya.
