Pre-Winter Maintenance 2015
Old Sep 21, 2015 | 10:20 PM
Firefighter 1406's Avatar
Firefighter 1406
Injector o rings
Glowplugs
Glowplug led now that it was mentioned
Front / rear rotors
Fuel filter
High amp alt w/ upgraded wires
Battery check/clean connections
That's the start. Hopefully that will get me by.
Old Sep 22, 2015 | 07:35 AM
F250_'s Avatar
F250_
While you're digging in...
1) pull all four wheels and inspect your brake pad thickness and rotor surface condition,
2) flush the brake fluid,
3) inspect tire tread carefully, AND
4) make sure you have good pressure on each corner (don't just eye-ball the tire height... put a gauge on each on to double check).
5) replace your wiper blades
Old Sep 22, 2015 | 09:04 AM
Tugly's Avatar
Tugly
Originally Posted by nlemerise
...cerveza, margaritas, and camarones!
Tacos Camarones, and Tacos al Pastor. {drool}
As for cervesa in Mexico, nothing short of Dos Equis. That Modelo stuff is toilet filler.
Slide pins! This is a task you don't want to do as a solution to a problem with snow and freezing temps on your hands.
Old Sep 22, 2015 | 09:38 AM
nlemerise's Avatar
nlemerise
I have a contact in Mexico for the best of the German beers...Spaten, Warsteiner, etc. Mexican beers are the equivalent of the worst of American beers with some added caramel for color. I will be sitting about a 1/2 mile from the best Tacos al Pastor in Sonora .
Old Sep 22, 2015 | 09:45 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Oil cooler o-rings!
Old Sep 22, 2015 | 10:50 AM
rufushusky's Avatar
rufushusky
1. Ambulance alternator & piggyback wiring
2. Clean out EBP sensor
3. New Serp belt
4. Power steering & Auto trans flush
5. Flush Brake fluid
6. Clean and lube slide pins
7. Backup camera
8. LED reverse lights
9. 400-500 pounds of counter-weight for plow
Old Sep 22, 2015 | 12:02 PM
SARDiverDan's Avatar
SARDiverDan
Originally Posted by Dave in Maine
['03 F250 Lariat, 4X4, auto]
As a newbie, keeping it simple -bought some DieselKleen in the silver (watching the forecasts).
I use the silver blend down here all the time, I think you need the white jug (anti-gel) and maybe a small red jug just in case up there in Maine.
I don't get much of a winter down here as we go from 100+ in the summer to 50-60's in the winter but people around here still complain. As I don't plan on driving out of the area this year, just routine stuff throughout the year like I always do.
Old Sep 22, 2015 | 04:26 PM
mjtpolice76's Avatar
mjtpolice76
Front leaf springs
Rancho 9000's all four corners
Front rotors
Front pads
Grease slide pins
Grease front hubs, and needle bearings
Fresh oil
Fresh fuel filter
New rancho steering stabilizer
Grind all rust off frame and cab.
Paint all with por15
New driver seat cover and foam
I
Old Sep 22, 2015 | 08:43 PM
F350-6's Avatar
F350-6
My POS factory GPR crapped out after only 500,000 miles. I've been putting off changing it, but guess I should since winter is coming.
Although I really like the sound of Neal's plans better.
Old Sep 22, 2015 | 09:16 PM
bigb56's Avatar
bigb56
Originally Posted by FiznUKa
The LED mod is simple just find a small 12v led light the size of a pencil eraser whatever color you like and install it where you can see it when you turn the key most people will put theirs in the gauge pillar that's where mine is and run a 2-way wire to the GPR relay one to ground and the other to the big lug that is only hot when the glow plugs are on. If you have the glow plug module I can't help ya.
Don't forget to throw an inline fuse in that puppy close to the relay.
Old Sep 22, 2015 | 09:18 PM
Mahir Sa'id's Avatar
Mahir Sa'id
glow plugs and glow plug relay sonds about right on my list
Old Sep 24, 2015 | 02:51 PM
Jaime74656's Avatar
Jaime74656
I always fuse my links (actually I usually use the inline circut breaker blocks that self reset after the fault has stopped, or the smart glow fuses)
as for the module any pictures of where the relay sits and looks like? how would I know if I have a relay verses a module?
I assume this is what I want to tap into??
Old Sep 24, 2015 | 07:29 PM
  #28
Thomas White's Avatar
Thomas White
Modules are found in all California Destination Trucks and in all Excursions
GPRM:
Glow Plug Relays are found in the remaining 49 States Destinations"
The Difference is the Module can control 1, 2...., or 8 at varying times. The Relay is On/Of.
Old Sep 24, 2015 | 07:43 PM
  #29
tjmike's Avatar
tjmike
Spray fluid film under the truck.
Old Sep 24, 2015 | 10:00 PM
  #30
Jaime74656's Avatar
Jaime74656
GPRM:
ok then I have the round relay option (yay) do we have any write up or a picture showing where I should tap into for the GP LED?? I plan to do that asap along with the CCV mod...
