Pcv
Old Sep 21, 2015 | 03:29 AM
Jly154's Avatar
Jly154
Pcv
Hey guys I've got a 95 f250 5.8 j had a question about. Could a bad Pcv valve cause my pickup to burn oil, leak and have more than normal oil in the tube going from the air box to the valve cover?
Old Sep 21, 2015 | 03:37 AM
Cruiseomatic's Avatar
Cruiseomatic
Definitely.
Old Sep 23, 2015 | 10:31 PM
Jly154's Avatar
Jly154
Originally Posted by Cruiseomatic
Definitely.
Ok thank you!
Old Sep 25, 2015 | 06:37 PM
choate's Avatar
choate
Yep. I was losing oil and it started kind of all of a sudden. Didn't use hardly any before. I replaced only the pcv and 2k miles later it's still at the top line of the dip stick
Old Sep 25, 2015 | 08:20 PM
jas88's Avatar
jas88
Also check to make sure you have vacuum going to the PCV valve. I have found the vacuum fitting on the back of the manifold plugged with carbon on some Windsor motors.
Austen Chelsea Fritz
May 13, 2016 10:48 AM
Zorfox
Jan 8, 2012 03:46 PM
92fordman
Aug 24, 2008 10:35 PM
dougandrochelle
Dec 23, 2003 10:22 AM
KJKozak2
Mar 3, 2002 09:20 PM
