screen under pcv valve?anyone know
Old Aug 24, 2008 | 08:28 PM
92fordman's Avatar
92fordman
its a 1992 f150 5.0
i was reading in the mustang forum about getting oil in the upper pleum and i saw a little filter that went under the pcv valve in like the 86'-95' mustangs
that looked like it would work if you could get in valve cover without losing it in the motor or did this come factory?any feedback would be great thanks
the part #FA1068
Old Aug 24, 2008 | 10:35 PM
quaddriver's Avatar
quaddriver
there is a sheetmetal baffle in the valve cover put there by the factory.
always 'on it', or bad rings will cause excessive blowby and the oil will come out of the vapor in the intake. It also cokes up the insides purty good. really nutting you can do about it
If you have oil in the pcv breather
(in the air box) then the rings are REALLY bad.
