Squeaking from truck
Old Sep 20, 2015 | 03:10 PM
Jaime74656's Avatar
Jaime74656
Ok just needing info, am I about to have any major issues as my truck is making a loud rhythmic squeaking noise when I move at any speed that is lower then what the speedometer will register (5mph or less) should I be concerned about the noise? It only occurred when I'm at very slow parking lot speeds
Old Sep 20, 2015 | 08:20 PM
crop harvester's Avatar
crop harvester
Check u-joints on drive line,or brakes
Old Sep 21, 2015 | 05:35 PM
Jaime74656's Avatar
Jaime74656
Ok I will check it out
Old Sep 21, 2015 | 08:17 PM
Thomas White's Avatar
Thomas White
No Info on your Truck listed.
Hubs as well make such sounds that will turn to grinding. Often silencing when turning at low speeds.
Old Sep 21, 2015 | 08:38 PM
jhl3's Avatar
jhl3
His truck is a 1999 F250 with about 250k on it...
Old Sep 21, 2015 | 09:58 PM
Thomas White
May be I'm blind! Dammed if I see anything like that. Is it a 4WD or 2WD?
Old Sep 24, 2015 | 02:58 PM
Jaime74656's Avatar
Jaime74656
info should be in sig, or on build thread but just incase its not (some time I use my phone to post on forums and it DOES NOT show my sig on those posts for some reason....)
1999 F250SD XLT with 441,100+ miles on the clock 4x2 LB
Old Sep 24, 2015 | 05:31 PM
Thomas White
Any luck in narrowing down the noise? Has it increased any?
Old Sep 24, 2015 | 09:58 PM
Jaime74656's Avatar
Jaime74656
no increase,k hoever at the moment my brother is borrowing my truck (preffer him to drive the trusty Ford then some POS economy hire car (rental car) that he was going to get (it was a toyota Prius of all things...) so he could get home to get to his job the next day so I will have the truck back in hand to further test tomorrow evening, but as far as he can tell no further noises are being emitted from the truck, only at 5mph or less (crawling in a parking lot)
mrc59
Dec 13, 2005 08:58 AM
celjel
Sep 25, 2005 04:30 AM
Geekboy1990
Oct 15, 2004 12:45 AM
ThomL
1978 - 1996 Big Bronco
Jan 22, 2004 09:38 AM
