Sponsored by: Real Truck
2008 V10 Acceleration Buzz
Old Sep 17, 2015 | 03:00 PM
tobyw's Avatar
tobyw
Over the past couple of weeks my truck has developed a pretty consistent metallic buzz on light/moderate acceleration. At first I thought it was a heat shield rattling, but I've been under it a dozen times and can't find anything loose to make the metallic buzz that I'm hearing... I can pound on several places in the exhaust system with my palm and it seems solid/connected everywhere Anyone else have a similar issue with a V10 truck??
Old Sep 17, 2015 | 03:33 PM
KrisF250's Avatar
KrisF250
Have same truck, just started hearing the same thing on mine. Very faint, radio has to be off to hear it. I had the 10M05 Catalytic service warranty work done and it developed shortly after that service. Just turned 72K miles ???????????????
Old Sep 17, 2015 | 04:30 PM
tobyw's Avatar
tobyw
What is that all about? I'll Google it, but can you give me some cliff notes???
Old Sep 17, 2015 | 04:40 PM
KrisF250's Avatar
KrisF250
Service bulletin 10M05, recall on the catalyst Y pipe. Basically premature catlytic converter failure. Have copy of original letter dated 10-2010 if you need it.
Old Sep 17, 2015 | 11:21 PM
Thor'sHammer's Avatar
Thor'sHammer
Check the heat shield that passes under the oil pan. The spot welds are kind of poor and can break.
Old Sep 18, 2015 | 08:09 AM
speakerfritz's Avatar
speakerfritz
can I trouble you for a copy
Old Oct 9, 2015 | 09:39 AM
tobyw's Avatar
tobyw
FOUND IT!!
It was the heat shield around the muffler. It finally got to the point where it would consistently buzz right at 1500rpm, so I had my wife hold it there while I crawled around under it and sure enough, the heat shield was vibrating like mad! A couple of large hose clamps later, it's quiet as a mouse
BlueOval5.0
Modular V10 (6.8l)
88
Jan 28, 2024 02:06 PM
landscapeguy
Nov 23, 2015 11:44 PM
demery
Oct 14, 2010 06:47 AM
nuckfan
Aug 11, 2006 05:21 PM
Big Sky
Jun 1, 2004 12:43 PM
