Testing fuel pressure
Old Sep 17, 2015 | 10:34 PM
Az_Green_Machine's Avatar
Az_Green_Machine
So I tested the glow plug harness. Want to make sure I tested it right, its should be the pin closest to the firewall and the one furthust from it right? I got 100 ohms on the passager side and 1 ohm on the drivers side. From what I've read it shouldn't be higher than 4 so am I gonna be replacing the passager side one?
Old Sep 18, 2015 | 11:35 AM
cowmilker08's Avatar
cowmilker08
Try shorting the big terminals on the GPR with a screwdriver for 30-45 seconds and then start it.
Old Sep 18, 2015 | 03:15 PM
Az_Green_Machine
So use a screwdriver to connect the two post and try to start it? I have 11.5 volts at both post already will that make a difference?
Old Sep 18, 2015 | 10:17 PM
cowmilker08
11.5 volts with the key off on both posts? That means your gpr is stuck on. Your batteries may be too low on juice to turn it over fast enough. If that is the case disconnect the large wire on the gpr that comes from the fender. Charge the batteries and try to start it.
Old Sep 19, 2015 | 12:03 PM
Az_Green_Machine
No thats with the key on. I had to go out of town for work so I'm away from the truck, its quite possible my batteries are no good, who knows when my grandpa last replaced them when I get back into town I'll test them luckily none of these parts by them selves are very expensive, it would suck to have to replace two batteries. I think I'm just going to make an emergency kit that will allow me to change the some of the more common problems, fuses, CPS, a UVCWH, and a GPR (I've read the new ones even the ford ones are junk)
If I have to change the UVCWH I'd it a good idea to swap the glow plugs while I'm there? Or do they generally not fail to often?
Old Sep 19, 2015 | 04:25 PM
cowmilker08
Ohm the GPs to see if they are working. I can't remember the correct resistance off the top of my head.
Old Sep 19, 2015 | 06:21 PM
Jarrett Campbell's Avatar
Jarrett Campbell
https://www.ford-trucks.com/forums/4...ke-thread.html
This will answer most any question about glow plugs/gpr/cold hard start.. did for me at least!
Old Oct 17, 2015 | 02:28 PM
Az_Green_Machine
Originally Posted by BBslider001
Hope this helps
Just wanted to post and thank everyone for the tips and ideas, ended up being a bad UVCWH, I went ahead and swapped glow plugs while I was in there. Trucks been running great. Now to sort out some electrical shorts, fix the speakers, and rebuild/upgrade the turbo
Hotairjunkie
Apr 23, 2024 04:33 PM
tomntractor
Jan 23, 2016 09:35 PM
powersmoked
1983 - 2012 Ranger & B-Series
Feb 22, 2010 03:24 PM
aussie01
Jan 9, 2010 05:31 PM
bscaff
1978 - 1996 Big Bronco
May 13, 2009 01:17 PM
