Wrong gas cap maybe???
Old Sep 19, 2015 | 07:28 PM
hoss73ford's Avatar
hoss73ford
So does mine. The filler pipe won't accept a more recent cap that clicks after it's tight. Don't think that came until the latter 80s or 90s.
Old Sep 19, 2015 | 07:30 PM
maytea's Avatar
maytea
No emissions
Brand is motorad
There appears to be a vent on inside but not on top
Old Sep 19, 2015 | 07:50 PM
maytea's Avatar
maytea
Oriely and autozone have similar caps marked vented, but they do not have the clk click feature of newer vehicles
http://www.autozone.com/fuel-deliver...p/4355_0_2695/
http://www.oreillyauto.com/site/c/de...3355&ppt=C0333
Old Sep 20, 2015 | 09:30 PM
maytea's Avatar
maytea
Good info on gas caps here
FORDification.net - The '73-'79 Ford Pickup Resource
Old Sep 21, 2015 | 12:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hoss73ford
I now have inside parking for my supercab. When I walk towards the rear, it reeks with fumes. No leaks or drips anywhere. Then I noticed if I remove the gas cap for a bit and let the pressure out and put it back on, the fumes quit for a while. The present cap is a Stant G751. Some NOS Ford caps show up on ebay well just about every week but I don't want to get the wrong one and parts stores often don't have a clue on these old trucks.
OH, my truck does not have evaporative emission which I understand takes a different cap.
D4TZ-9030-A (replaced D3TZ-9030-A) .. Fuel Cap-Vented-Use without Evaporative Emission / Handle on top of cap / Primered finish (Motorcraft FC-98-A) / Obsolete
1973/76 F100/250 Stylesides with Mid-Ship and/or Aft Axle fuel tanks / 1973/74 F350's on the 140" wheelbase with Mid-Ship and/or Aft Axle fuel tanks.
1973/76 Stylesides have exposed fuel caps, use different fuel caps than 1977/79 Stylesides that have fuel doors (1977/79 example in post #17).
HAVEN FORD in Haven KS has 1 = 620-465-2252.
BARRY MOTOR CO. in Danbury IA has 1 = 712-883-2421.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
Old Sep 21, 2015 | 12:48 PM
maytea's Avatar
maytea
Thanks for clarification on the 77/79 with fuel doors needing a different gas cap
One thing that looks strange to me is the non evap gas caps seam to have a pair of legs that fit deeper into the fill tube. What is reason for these longer legs?
Old Sep 21, 2015 | 12:55 PM
NumberDummy
Non vented Evaporative Emission fuel caps have 4 prongs, 2 above, 2 below 180 degrees apart.
Old Sep 21, 2015 | 03:42 PM
maytea's Avatar
maytea
Thats strange as the two pics I gave are listed as vented caps used without EV/EM
D8TZ-9030-A: 7/78 F150/350 (99) - without ev/em;
Motorcraft FC-807 - 2 5/8" O.D. - handle on top of cap - zinc plate finish - use w/aft axle and/or midship fuel tank
D7TZ-9030-K : 77 F150/350 - without ev/em:
Motorcraft FC-791 - 3 1/2" O.D. - vented - knurled edge on cap - primer finish - use with in-cab fuel tank
Must be bad info over at
Old Sep 21, 2015 | 07:04 PM
NumberDummy
D8TZ-9030-C replaced D7TZ-9030-K : 77/78 F150/350 - without ev/em:
This info is straight from the 1973/79 Ford Light Truck Parts Catalog.
The problem is, you another members thread asking about fuel caps that have nothing to do with the OP's truck.
Old Nov 26, 2017 | 06:15 PM
lalberts's Avatar
lalberts
Originally Posted by Blue and White
I run a parts store vented cap. It has a pressure relief valve which holds quite a bit of pressure or vacuum before it vents. Pressure means leaks or fumes and vacuum may cause vapor lock. I didn't care for that so I "fixed" it. A strategically placed 1/16" hole in the cap and no more problems.
I Just did the same exact thing to mine cuz alota tim es there is alota pressure built up in that tank. I don't think thats good for the carb or fuel pump.Not to mention the fuel tank.
BeauF0RD
Jun 14, 2017 12:30 PM
69issofine
Dec 10, 2014 12:59 PM
lute
15
Mar 9, 2013 11:36 AM
bubbafrye
Aug 6, 2012 11:45 AM
grm61
Apr 22, 2010 09:22 PM
