Distibutor ID
Old Sep 15, 2015 | 11:34 AM
jayboundless's Avatar
jayboundless
Distibutor ID
Hi all, New to this forum. Just purchased a 1962 Ford Econoline PU and trying to identify the distributor that is currently installed. Pretty sure it is not stock as I tried to buy cap and rotor and they don't match what is called for. It is a Autolite d0df 12127 C. Can anyone tell me what vehicle this came off of? Also, not sure of the engine size. It's obviously a straight 6 but not sure if a 144cui or 170cui. Is there a marking on the block? I think I read somewhere else the that you had to have the heads off?
Thanks in advance!
Old Sep 17, 2015 | 06:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jayboundless
Hi all, New to this forum. Just purchased a 1962 Ford Econoline PU and trying to identify the distributor that is currently installed. Pretty sure it is not stock as I tried to buy cap and rotor and they don't match what is called for. It is a Autolite ID number: D0DF-12127-C. Can anyone tell me what vehicle this came off of? Also, not sure of the engine size. It's obviously a straight 6 but not sure if a 144cui or 170cui. Is there a marking on the block? I think I read somewhere else the that you had to have the heads off?
It's possible the engine's been swapped because this distributor is from a 1970 Falcon or Maverick 200 I-6
ID number: D0DF-12127-C = Ford part number D0DZ-12127-C
The original engine size could have been either a 144 or 170 I-6, 4th digit of the VIN is the engine code, post what it is.
You can measure the stroke to determine what the engine size is now. The 144/170 has 3 large freeze plugs on the right (passenger) side of the block, the 200 has 5.
Stroke: 144 = 2.50" / 170 = 2.94" / 200 = 3.13"
Old Sep 17, 2015 | 05:00 PM
jayboundless
Thanks on the distributor help. The VIN is E10TH221224
Old Sep 17, 2015 | 05:04 PM
NumberDummy
E10 = E100 Pickup.
T = 170 1V I-6.
H = Lorain Ohio Assembly Plant.
221224 = 1962, assembled October 1961.
stm76
Oct 1, 2018 04:37 PM
briangregory
Sep 15, 2018 05:53 PM
jayboundless
1961 - 1963 F100 Unibody
Sep 17, 2015 05:41 AM
tinman52
Jan 9, 2010 06:56 AM
TxF100
Jan 24, 2009 03:33 PM
