distributor cap part number
Old Sep 12, 2018 | 04:55 PM
briangregory's Avatar
briangregory
Hi Guys, Can anybody verify that part number D5AZ12106A is for a 1968 F250 camper special with 390 FE block?
The truck has blue paint, if that helps.
Thank you in advance
Old Sep 13, 2018 | 03:55 AM
GaryKip's Avatar
GaryKip
Here ya go:
Dist Parts:Points, condenser, rotor, cap same ALL 1957/73 V8's, also same 1974/75 V8's except with DuraSpark electronic ignition.
B7A-12106-A .. Distributor Cap (Motorcraft DH-6).
B7A-12200-A .. Rotor (Motorcraft DR-5).
Old Sep 13, 2018 | 10:27 AM
briangregory
Thanks Gary
Thanks Gary! I found a dealership out of state that has an original motor craft dist cap. The part number is D5AZ12106A.
i would have to assume it’s same part because last numbers are the same. I have seen it with other letters and numbers but as long as it ends in 12106A, it is all the same, right? It Would have to be bescause like you said, the cap fits many years and vehicles. All this is because I like to use points. It’s more pure. If you use points you have to insist on authentic Ford parts. I just never got around to the distributor cap til now so thanks!
Old Sep 13, 2018 | 10:54 AM
briangregory
DH 354
the guy said the box says DH 354. Does this fit a 1968 390 FE? Maybe same part with two part numbers?
Old Sep 13, 2018 | 03:14 PM
KULTULZ's Avatar
KULTULZ
D5AZ 12016-A (DH354) is a higher dialectic version of the original B7A 12106-A cap (BLACK). It will work.
12106 is the BASIC PART NUMBER for a DIST CAP. D5AZ indicates 1975 as the intro year for service. DH354 is the MOTORCRAFT PART NUMBER.
Old Sep 14, 2018 | 11:13 AM
JEFFFAFA's Avatar
JEFFFAFA
2X. By 1975 Fords had electronic ignition. Some in 1974. These had a hotter spark. So 1975 Ford introduced a new coil, 8mm plug wires, the D5AZ cap, and a rotor. So you can poke 7mm or 8mm plug wires in the D5AZ cap.
Old Sep 14, 2018 | 02:50 PM
briangregory
Very cool. I have blue streak 8mm set from standard motor products via Rock Auto. Side note: you can’t call them anymore. Website only
Old Sep 14, 2018 | 06:57 PM
KULTULZ's Avatar
KULTULZ
Question
If you can, what is the PN on the 75 rotor? I don't have that period MPC anymore.
Old Sep 15, 2018 | 11:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5AZ-12200-A .. Rotor (Motorcraft DR-5-A).
DuraSpark electronic ignition introduced in 1974, but not all Passenger Cars, F100/350's, Bronco's and Econolines had it until 1976.
The D5AZ-12106-A dizzy cap replaced the B7AZ-12106-A HiPo/Heavy Duty cap that was tan.
B7A-12106-A black cap was not replaced.
Old Sep 15, 2018 | 05:53 PM
KULTULZ's Avatar
KULTULZ
THANK YOU BILL!
TheKirbyMan
16
Jan 11, 2013 10:39 PM
55fordv8
Jun 8, 2012 12:09 PM
rob8210
Feb 20, 2010 10:28 PM
smkf100
Oct 27, 2009 05:40 PM
Goose_52
Apr 14, 2008 04:11 PM
