Sponsored by: Auxito
Right front brake siezing??
Old Sep 14, 2015 | 04:16 PM
Sixoh's Avatar
Sixoh
This began a few months ago. At first came and went, made the front end shimmy. I realized the caliper was sticking, so I replaced it with new pads both sides.
Here we are a month later and it's been siezing again and has chewed the pad to nothing. FLAT OUT SIEZING and won't let go of the rotor.
What's going on? Prop valve problem?
Shane
Old Sep 14, 2015 | 05:16 PM
85e150's Avatar
85e150
You replaced the whole caliper or just the pads?
Brake lines can fail internally causing residual pressure at the caliper. You can probably check this with the bleeder valve, see how much pressure you have on one vs. the other side.
Old Sep 14, 2015 | 05:47 PM
steve(ill)'s Avatar
steve(ill)
it can also be the puck (piston) is stuck in the bore and will not retract when the oil pressure drops.. Sometimes you need to remove the rubber and clean the piston wall so it will enter the bore.
Old Sep 15, 2015 | 02:44 AM
Icefan71's Avatar
Icefan71
Also, check the caliper pins. They should be able to slide back and forth freely. I had to replace rotor, wheel bearing, and caliper on a Toyota Camry all because the caliper pins were crudded up and stuck and produced a lot of heat. Pins are cheap to replace and easy to clean.
Old Sep 15, 2015 | 08:08 AM
Sixoh's Avatar
Sixoh
Very good. I'll check it out again. This truck has 193,300 on it and looks and runs like a spry 60k.
I have inspected the caliper after replacing it and the pins etc are all lubricated. I will check the piston.
Also going to replace the pads just to buy time for replacement of the other caliper and rotors. I will make an appt to have the fluid flushed and changed as well.....I can do it but it's a hassle Lol I prefer getting dirty on my old cars!
Old Sep 18, 2015 | 11:01 PM
FordTruckChuck's Avatar
FordTruckChuck
Can this be done without removing the caliper from the truck?
Old Oct 8, 2015 | 08:19 AM
JSPajak's Avatar
JSPajak
Replace the rubber brake line that goes from the frame to the caliper. There is a metal bracket in the middle of the line and it's famous for rusting and squeezing the line almost shut!
F350 King Rancher
2009 - 2014 F150
Jul 27, 2017 06:01 AM
brownie83
Sep 21, 2011 06:28 AM
79 sb150
Jan 11, 2006 12:15 PM
I6power
Mar 23, 2005 03:52 AM
nuts4hotwheels
Mar 12, 2005 06:47 PM
