Brake pad rubbing
Drive it till it starts to drag. Jack it up, try spinning the wheel then crack the bleeder open to release the pressure and spin the wheel.
If the wheel spins freely it is a hydraulic problem.
A: a crushed or twisted steel brake line. Inspect and replace as needed.
B: a brake hose that is collapsing on the inside acting as a check valve. Replace.
If the wheel still drags it is a mechanical problem.
A: Rusted/frozen caliper pins. Clean, lubricate, or replace if neccesary.(the caliper should move freely in and out,try it with the caliper installed but no pads)
B: Rusted/frozen piston in the caliper. ( piston should retract slightly when brake pressure is released. again the caliper should be able to move in and out but to a lesser extent.) Rebuild or replace.
C: Warped rotor/excessive runout. Replace rotor.
good luck
