Aerostar Ford Aerostar
Brake Line Question
Old Sep 13, 2015 | 09:36 PM
IronJedi's Avatar
IronJedi
Brake Line Question
So I lost brake pressure this morning. Pretty sure this rusted steel line is the culprit (pictures are of either end) that runs just passenger side of center along the frame rail, through a flange (first pic), bends 90 degrees and then screws into an adapter at another flange (second pic).
My question is this: In the first pic it looks like the "rigid" steel line meets a flex line just after that flange/holder.Are these two separate lines? If so, how are joined? Do I have to replace the entire line from the master cylinder back? Or is there a way to join a new piece of steel line to that "flex" line?
Old Sep 14, 2015 | 07:14 AM
DFord's Avatar
DFord
That's not a "flex" section of tubing.
It's just regular steel tubing reinforced with a wire wrapped around it.
Myfreeford
Jul 30, 2014 02:07 PM
Will-Power
Sep 9, 2010 12:59 AM
Dstosh
Aug 24, 2008 02:56 AM
cbjr61
Sep 21, 2007 05:33 PM
FLJ
Feb 18, 2006 05:42 PM
