difficult starts
Old Sep 12, 2015 | 09:02 PM
crelyea's Avatar
crelyea
difficult starts
I have a PS 6.0 in my '04F350 that starts very reliably but stalls within 1-2 seconds. Restarts after cranking for 5-30 seconds. This only occurs if the truck sits for more than 6 hours. The longer the truck sits, the longer it has to crank to restart. Also if the tank is full and the truck is parked pointing down hill this does not occur, if it is parked pointing up hill it occurs even with a full tank. Shows no codes. I've had several mechanics look at it and no one has been able to explain or propose a solution expect for wholesale replacement of parts. The symptoms indicate to me that air is getting into the fuel system but I'm not sure where to look. Please advise.
Thank you in advance.
CRelyea
Old Sep 12, 2015 | 09:17 PM
z31freakify's Avatar
z31freakify
Just shooting in the dark but, it may be that your oil pick up tube may be cracked or broken and not allowing your lp oil pump, supply the oil necessary for your hpop to build enough pressure to fire your injectors.
Old Sep 12, 2015 | 09:21 PM
crelyea's Avatar
crelyea
We have checked the pressure and oil pressure is normal. Besides, I believe that low pressure would generate a code. I'm not sure. I've replaced the pressure switch with no affect.
Old Sep 13, 2015 | 04:44 AM
bismic's Avatar
bismic
Does it have OEM fuel filters?
Might as well ask about the oil also, does it have an OEM oil filter and an OEM oil filter cap?
What scan tools were used when checking for codes?
Old Sep 13, 2015 | 09:21 AM
crelyea's Avatar
crelyea
The current filter is not OEM but the cap is. I replaced the cap and O-ring several months ago to no avail. I've used OEM filters and this also had no affect. Thank you for your input. Please chime in if you think of anything else.
Perhaps another clue...the longer the truck sits....the longer it has to crank after the initial stall before it will eventually restart. During extended cranking, it will sometimes start or sputter several times before it eventually resolves.
It seems that there is a fuel supply interruption as if air is somehow getting into the fuel system. I know that there is a check valve in the fuel pickup, but even if this isn't maintaining pressure, wouldn't air have to be finding its way into the system? I'm perplexed.
Old Sep 13, 2015 | 09:34 AM
KDAVID1's Avatar
KDAVID1
difficult starts
You have a hpo leak. The place that feeds the hpop is draining dry (so to speak) there are a few posts on here with your exact symtom (nose down or nose up parking) if I remember correctly I think their issue was hpo leak.
Old Sep 13, 2015 | 09:51 AM
crelyea's Avatar
crelyea
Thanks for the insight...I'll look at this further.
Old Sep 13, 2015 | 01:16 PM
bismic's Avatar
bismic
Do you have gauges that can read the engine parameters (also - what scantool have you been using)?
Also, the issue described by cheezit in past posts (no-starts w/ nose up orientation) were connected to a bad HPOP or a failed o-ring at the pump side feed circuit (o-ring from pump to block).
https://www.ford-trucks.com/forums/9...-included.html
Old Sep 13, 2015 | 01:47 PM
KDAVID1's Avatar
KDAVID1
As usual bismic is the man!!!
Old Sep 13, 2015 | 01:57 PM
bismic's Avatar
bismic
well, you connected the dots ................ I just have the spreadsheets well organized!
reps sent
Old Sep 13, 2015 | 07:32 PM
KDAVID1's Avatar
KDAVID1
reps sent
Thank you sir and YES YOU DO. You're the best in the biz so to speak.
jason poeppel
Mar 23, 2017 01:23 PM
jhprice
Mar 4, 2015 07:16 PM
Scoarch
Nov 19, 2012 07:26 AM
jchase23
Oct 31, 2010 09:04 PM
rpusimak
Sep 9, 2010 10:03 PM
