1975 ford engine Question
Old Sep 12, 2015 | 08:54 PM
Bsemig's Avatar
Bsemig
OK so i have a 1975 with a 390 it is faqctory original however i would like to make it more modern. Does anyone know how i can go about doing that? I wann convert it to fuel injected and up date the distributor things of that nature. Please let me know
Old Sep 12, 2015 | 09:02 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
While it certainly can be done, there is a pretty steep cost associated with doing so, at least in terms of "payback". I believe there are single point EFI manifolds available and things like that. Maybe $2500 -$3000? I don't see the point particularly.
Old Sep 12, 2015 | 09:11 PM
Bsemig's Avatar
Bsemig
its the original motor and id like to keep it original as much as possible. I know im gonna be spending extra for it.
Old Sep 12, 2015 | 09:15 PM
fuzzybob's Avatar
fuzzybob
If original it's probably a 360.
Old Sep 12, 2015 | 09:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
On sale day, 360's magically become 390's!
4th digit of the VIN is the engine code. 1973/76 F100/350: H = 390 2V / M = 390 4V (1974/76) / Y = 360 2V
390's not available with 4WD.
Old Sep 12, 2015 | 10:02 PM
Tedster9's Avatar
Tedster9
Well, you can't keep it original, and make it more modern?
With that said a carburetor rebuild, good tune-up and maybe a fresh distributor, electronic ignition, etc will probably be about as good as it gets anyway. Don't forget to spend money on "whoa" as well as "go". Brakes, tires and suspension are important.
First step generally speaking though, is perform a compression check on each cylinder with the throttle held wide open. The procedure is on pg. 2 of my Motors Manual (and pg.1 is the table of contents.)
The reason or thinking behind a compression check first thing, if the engine particularly the pistons and rings are not mechanically sound there is little point investigating further or spending more money as such. Engine itself needs replaced or, a complete rebuild. If it passes this test, then the engine is generally OK candidate for tuning up and should respond well to your attention and last a long time.
But don't waste your time or money till you do this first. A vacuum gauge will work as well for this purpose to some degree, and has a lot of other uses as well. I recommend them highly.
Old Sep 13, 2015 | 12:16 AM
HIO Silver's Avatar
HIO Silver
Open hood.
Remove radiator cap.
Back up truck and discard.
Drive low mileage 94-96 F150 under radiator cap.
Install radiator cap...... voila.
Old Sep 13, 2015 | 12:31 AM
rougeriver's Avatar
rougeriver
Originally Posted by HIO Silver
Open hood.
Now that's funny! Good one, HIO!
David
30dodge
Sep 13, 2009 09:37 AM
Beaux
Dec 5, 2004 05:34 PM
MofoMike
16
May 1, 2003 05:10 PM
77F2
Feb 7, 2003 06:25 AM
smaynor
Sep 30, 2001 02:02 AM
