Shifter handles vibration
Old Sep 10, 2015 | 07:04 PM
derrickmauk1003's Avatar
derrickmauk1003
1988 f150 4x4 302 with a M5OD manual trans.
I have 31" mud grips on the truck with no lift on the truck.
When I get to about 65 mph the shifter vibrates pretty strong and the transfer case shift vibrates even worse. It only happens at higher speed so its not an RPM issue.
Old Sep 10, 2015 | 09:15 PM
Mudsport96's Avatar
Mudsport96
Does it do it in 4th and 5th @ 65? It could be a driveshaft imbalance or ujoint problem
Old Sep 10, 2015 | 09:17 PM
derrickmauk1003
Yes it starts to do it in 4th just as I get to speed and continues in 5th
Old Sep 11, 2015 | 10:45 AM
Mudsport96's Avatar
Mudsport96
I would check the u-joints and also look for play where the driveshaft slides into the back of the transfer case. Mine has some play there and I think that's where my vibration at 70 comes from.
Old Sep 11, 2015 | 10:53 AM
Shadow944795's Avatar
Shadow944795
On mine its got a slight vibration but nothing I can't live with, the only time I have ever worried about the vibration was at stupidly high speeds and my only reason for concern was that I had no desire to see a drive-shaft eject from my truck that day. But like the others said it could be an imbalance that needs correction or U-joint issues.
88PONY
Mar 2, 2008 11:19 AM
Spanky Bunny
Feb 17, 2005 06:41 AM
Josh79
Nov 25, 2003 09:50 PM
Skagit
1978 - 1996 Big Bronco
Apr 25, 2003 10:23 PM
