Bad vibration
Old Feb 29, 2008 | 07:49 AM
88PONY's Avatar
88PONY
Question Bad vibration
got a really bad vibration comming from the shifter on my 91 f250 4x4 5-speed. its fine around town but on the highway forget it its sooooooo annoying. any help would be great!!!
Old Feb 29, 2008 | 08:15 AM
BChance's Avatar
BChance
Does it change when you get on/off the gas? If so I would start the hunt at the u joints first.
Old Feb 29, 2008 | 09:02 AM
88PONY's Avatar
88PONY
no, just at highway speeds....could it be some kinda shifter bushing???
Old Feb 29, 2008 | 07:16 PM
88PONY's Avatar
88PONY
ok, found the problem....the yoke nut is sheered off and the yoke is slipping of the end of the transfer case....what case is in this truck ya think???
Old Feb 29, 2008 | 09:40 PM
flareside_thunder's Avatar
flareside_thunder
Is it a light duty or heavy duty truck?It's probly got a BW 1356 transfer case...unless they kept running the 208's into those years...should be a tag on the T-case on the back...if it's round with blue righting it's a NP...luck
JR
Old Feb 29, 2008 | 10:53 PM
88PONY's Avatar
88PONY
its gotta be a light duty. its an xlt lariat with a 5.0l and 5speed its kinda dogish...lol i know the case says borg warner, and it is a manual shift
Old Mar 1, 2008 | 07:45 AM
SpeedRebel09's Avatar
SpeedRebel09
yeah I think it's what I got in my f-150, the borg-warner 1356.
Old Mar 1, 2008 | 01:55 PM
flareside_thunder
Yea most likely is a 1356....don't rule out a bad tranny mount either.....just cause it ain't slingin back and forth from one side of the cab to the other don't mean it ain't bad....
JR
Old Mar 1, 2008 | 08:38 PM
88PONY's Avatar
88PONY
ok, now i see some of these xfer cases ar manual or auto shift. does it really matter??? my truck is manual
Old Mar 2, 2008 | 11:19 AM
flareside_thunder
The only difference between the two are auto locking hubs..and the electric motor that shifts the xcase from 2wd to 4wd(pushbutton on the dash)The U joints n such should be the same.
JR
