transfer case shifter vibration
Old Nov 25, 2003 | 05:28 PM
Josh79's Avatar
Josh79
i have started to notice that the shifter for the transfer case is starting to shake and i dont think it always did this so i was wondering if this is normal or if i need to tighten something up? it does it in 2wd and 4wd. any help would be appreciated
Old Nov 25, 2003 | 08:45 PM
MythotiK's Avatar
MythotiK
Mine did the same thing...When I replaced my motor and tranny, I put a washer in between the handle and bolt...Hope it helps, mine has been rattle free...
Old Nov 25, 2003 | 09:50 PM
plowpusher's Avatar
plowpusher
the t-case shifter rides on a nylon bushing it may be worn but if it just started check the usual suspects like u-joints mounts and linkages is it a manual tranny when is it worst or least for instance i had a simular vibration turned into a bad output bearing in the tranny
NWO_diesel_nut
Dec 30, 2013 11:02 AM
Yougotthehit
Nov 1, 2009 12:01 PM
96_Skyjacked
Jul 26, 2006 09:02 AM
Mark Kovalsky
Dec 4, 2001 08:39 AM
