ignition control module
Old Sep 10, 2015 | 03:59 PM
nevergivenup123's Avatar
nevergivenup123
I have a 1985 f-150 with A 4.9 liter. I've been having problems with the ECM. I purchased a aftermarket distributor that just has A pigtail that has a three prong female plug. I'm trying to get away from the ignition control module. Is there any way in my truck's wiring harness to wire in this different pigtail? The original pigtail is 6 wires. Can anyone tell me how this can be done? Thank you...
Old Sep 10, 2015 | 05:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sounds like a DSII swap.
What colors are the wires?
Black, orange and purple?
Does it have a vacuum advance?
You wil need the blue Duraspark module, a DSII compatible coil and the OEM harness between the three.
All the other wiring and plugs already exist in your truck's harness.
Old Sep 10, 2015 | 05:27 PM
nevergivenup123
OK thanks for the reply. I'll have to check the wire colors. But what I don't understand is when you do a search on distributors for that year and engine it has two different ones available.
Old Sep 10, 2015 | 05:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 4.9 was available in an F250..
Heavier trucks had different emissions and came with the DSII ignition.
This is the same deal as the 351W in a 150 or the 351W HO in a 250/350
Old Sep 10, 2015 | 05:35 PM
nevergivenup123
Everything you said I would need were would be the best place to purchase these parts?
Old Sep 10, 2015 | 05:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The coil and module can be found through any LAP.
I would suggest a quality module like the Echlin TP40 over a $19.95 module from Autozone.
The harness is a junkyard item and will include the proper distributor and coil connector, and a socket for the o/p/b pigtail of the module.
You will likely need to unwrap a bit of the harness on your fender in order to find the white and red DSII socket to plug into the other side of the module.
Painless wiring makes one but it is stupid expensive and reports say the four pin connector is miswired from the jumper.
Old Sep 10, 2015 | 05:57 PM
nevergivenup123
OK thanks alot. You've been alot of help. My name is Adam. I just became a member today. I've had my f150 for about 10 yrs. Hopefully after I make these changes it will solve this ecm problem. Thanks again. TTYL
Old Sep 10, 2015 | 06:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Welcome to the forum Adam!
I'm on my phone so I don't see any sigs or post numbers or anything like that.
Have you ever considered just relocating your TFI to a heatsink?
There are two sites I can think of that sell a harness.
One is a a Mustang page, the other a Miata/5.0l swap page.
http://www.mccullyracingmotors.com/index_files/tfikits.htm
http://www.fatfoxx.com/products.php
Old Sep 12, 2015 | 02:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You wil need the blue Duraspark module...
DuraSpark ignition modules are identified by a colored plastic square above where the fires feed out.
1U2Z-12A199-AA (replaced D6AZ-12A199-B & D9VZ-11A199-A) .. Ignition Module - Blue (Motorcraft DY-893) / Available from Ford & auto parts stores.
Applications: Myriad 1976/90's FoMoCo vehicles.
LARIAT 85
38
Jan 9, 2016 12:48 PM
zeus77
Jan 23, 2008 10:52 AM
smitty7
Dec 14, 2004 02:17 PM
brokenrings
Electrical Systems/Wiring
Sep 17, 2003 02:21 PM
idealtrucks
Feb 4, 2003 06:35 AM
