Hello everyone, i just bought a "sunpro super tach II" and hooked it up to the green wire that is i "hope" the negative side of the ignition coil. (there is only 3 wires) so i get going down the road and it says that all i can get for rpm's is about 2800. i know the ol' 460 can pull more r's than that.... i think i hooked the green wire up to the wrong wire or something because that can't be right, i'm sure at least someone has gone through what i have
read this thread a bit late, and actualy came across it while looking for the same answers. . .
anyhow here goes.
the wire on the ignition module/coil is the dark green w/yellow stripe for the year you are asking about.
for a complete list of all ford applications for sunpro tach's, see heresunpro tach tech
