Hub Tool ?'s
Old Sep 8, 2015 | 03:42 PM
cowboy1381's Avatar
cowboy1381
Hub Tool ?'s
It has been awhile (thank God) since I have had to take the front hubs apart on a Ford 4x4 I have a 97 350 with manual hubs. I took the front grease cover off, the outer wheel bearing, then an annoying retaining ring, followed by a few washers and other rings. now I am confronted with a nut that I remember from doing my 94 F-150 4 slots socket looking tool needed. however when I dusted off the tool I used on my 150 it appears to small for my 350 am I just loosing my mind or did ford actually use 2 different sizes?
Old Sep 8, 2015 | 03:45 PM
cowboy1381's Avatar
cowboy1381
It has been a long long day and I have started making stupid mistakes that's why I have to ask. I feel like maybe I am missing something obvious.
Old Sep 8, 2015 | 04:11 PM
rla2005's Avatar
rla2005
The F250/350 use a larger spindle nut. I have a Great Neck 25966 socket for this purpose.
OEM 25966 1/2-Inch 76 by 80mm Front Wheel Bearing Locknut Socket - - Amazon.com OEM 25966 1/2-Inch 76 by 80mm Front Wheel Bearing Locknut Socket - - Amazon.com
Nothing Special's Avatar
Nothing Special
Yes F-350s use a different spindle nut that requires a different spindle nut wrench than an F-150 (some F-250s use the F-150 nut and wrench, others use the F-350, so there are only 2 thankfully).
But you don't get the outer wheel bearing off until after the spindle nuts are off, so either you don't have the outer wheel bearing off yet or your talking about a different nut requiring a 4 slots socket looking tool (6 slots actually on an F-350 I think).
Old Sep 8, 2015 | 04:15 PM
ichabod40's Avatar
ichabod40
There are two different sizes tools. One for the Dana 44 found in F-150s and F-250s and a different one for the Dana 50 found in some F-250s and the Dana 60 found in F-350s.
Old Sep 8, 2015 | 05:20 PM
daddylee100's Avatar
daddylee100
Hub Tool ?'s
Just got doing mine, bought it on amazon for 22$ tried autozone and theirs was way to small.
OldWoodsDiesel
Jul 10, 2013 07:06 PM
trevorrules
16
Jun 18, 2013 09:18 AM
busch6062
Sep 4, 2012 04:48 PM
cowmilker08
21
Jun 4, 2010 09:29 PM
99f350sd
Mar 3, 2006 04:05 PM
