Idea for Hpop
Old Sep 4, 2015 | 01:20 PM
hotrodfeguy's Avatar
hotrodfeguy
Idea for Hpop
I had a idea that came to me from the other thread. Would it be possible to install a magnet much like in a transmission. When the HPOP goes bad I would imagine it sends out metal at the injectors. This would capture the metal before it goes out towards them if a failure were to occur. Or maybe even a prefilter situation to the HPOP in the reservoir if that makes sense in trying to make things last longer? What are your thoughts?
Old Sep 4, 2015 | 06:38 PM
F350-6's Avatar
F350-6
Of all the HPOP failures I can recall, I don't remember one of them taking out the injectors. The HPOP isn't quite like the HPFP on the new trucks that really screw things up when they go bad.
As for a magnet or filter, or magnetic filter like Magnifine, remember you're dealing with pressures up to around 3,000 psi. That's going to tear most filters apart or slip by most magnets, unless it's so strong that it restricts flow.
On paper it's a good idea. In reality, it's just not needed.
Old Sep 4, 2015 | 07:52 PM
hotrodfeguy
I dont think 3,000 psi is going to destroy a magnet.
Old Sep 5, 2015 | 07:22 AM
F350-6's Avatar
F350-6
No, but it will shoot small metal pieces right past the magnet.
Old Sep 5, 2015 | 09:26 AM
Tugly's Avatar
Tugly
Naw... the flow is very low, so any metal filings will just ooze by the magnet. The problem is where to put the magnet on the HP side: The ICP flows straight to the hoses and into the oil rail in the heads. There is no HPO reservoir, therefore no place for a magnet to rest without risking dislodging and plugging the flow.
Interesting concept, but the reality under the hood makes this a daunting task without serious mods - like a HPO manifold.
Apocalypse
Sep 22, 2017 12:44 AM
DesertZuki
Dec 21, 2015 10:59 PM
MisterCMK
May 5, 2014 05:59 PM
DENALI
Apr 7, 2014 09:11 PM
LSO1123
13
Jul 30, 2011 10:42 AM
