Don't waste your money on RevX, HSS, etc. Buy the Alliant o-ring kit, some 800 grit wet/dry sandpaper and polish the spools in the injectors.
I just got done with the driver side injectors on my truck and all of my stiction issues are gone now. It was bad enough that the truck was missing occasionally all the way up to 150* EOT. Now I don't have any missing.
I should probably do the passenger side as well but the driver side took care of it all.
Man seems like a big job!! How long did it take ya?
I've never done this before and with horsing around it was 6 hours for that side. I could do it in half that now.
I did re-ring all of the injectors. That top oil rail o-ring is a bit of a treat but after the first 2 they are quick.
Thats not to bad, I'm sure it would take me twice aslong.. But atleast your not masking your stiction anymore, and it is fixed!! Thats worth the piece of mind in its self in my opionion..
#3 injector was driving me nuts.Alcohol and scotchbrite on the spool valve and all was good.I was just on the verge of buying new injector..............
Part number for the alliant o-ring kit? Any other parts necessary?
Inductive heating is what covered up mine, I put two and two together when I noticed my truck missing while cruising on the freeway.
It was much better with the T6 and RevX but I could still feel it. I only used 4oz at a time though. I still have the Rotella T5 10W-30 in the truck right now with nothing in it.
