Wheels....A certain look I'm going for
Sep 3, 2015 | 08:28 PM
Sep 3, 2015 | 08:56 PM
They are just stock wheels and I believe mod 80's hub caps.
Sep 3, 2015 | 11:42 PM
Moderator & parts slinger
Both trucks have stock steel rims and hub caps. 2nd truck the rims almost look to narrow or the tires are to wide, see all the rolled side wall....
Sep 3, 2015 | 11:57 PM
Quote:
Originally Posted by
77&79F250
TYPE 12: The blue trucks 4WD front hubcaps were introduced in 1984 (
E4TZ-1130-A ). The rear 4WD hubcaps (same as 2WD) were introduced in 1978.
Sep 4, 2015 | 09:42 AM
Thanks numbers & 77_79! Would those hub caps work if I were to have a replica stock wheel made in a 17x8.5"?
Sep 4, 2015 | 11:22 AM
No idea if the 2 trucks in the pics have 16.5 or 16's...Why not just get some stock steel wheels from a newer Ford from a JY, up to a 98 they are 8 on 6 1/2?
And I would bet they would be 16's. No idea on the hubcap mount up.
Ford went metric 8 on 177MM in 99, if I remember right.
Sep 4, 2015 | 11:30 AM
It's 8x170mm for the trucks but the vans still used the old 8 on 6.5" spacing. I never looked but I bet they have the hub cap mount on the newer ones.
Sep 4, 2015 | 11:33 AM
And that is why FTE Rocks!
I always forget that even newer vans still use the 8 on 6 1/2 and I am sure they are at least 16's.
Sep 4, 2015 | 12:12 PM
I've found them on Dennis Carpenter's website!
Sep 4, 2015 | 01:03 PM
Top one looks like Type 10's.
Sep 4, 2015 | 08:15 PM
I'm finding very few good sized tires that fit on a 16x6 wheel. Any suggestions?
Sep 4, 2015 | 08:42 PM
On a 6" wide rim, you will probably not be able to run anything very wide. 7.5" or 8" might be a better width rim?
StinsonSteve
Jan 24, 2019 01:44 PM
catto95
Mar 16, 2018 01:24 PM
grasfarmr73
28
Jul 25, 2017 12:15 AM
Lgilliland
Apr 6, 2015 03:32 PM
2bocat
20
May 25, 2010 10:33 PM
