door seals
Old Sep 3, 2015 | 02:27 PM
beartracks's Avatar
beartracks
door seals
A few months ago I replaced my door seals, striker post and lock assemblies. I still can't get the doors tight. the front edge is a little shy of even and the back edge of the door is a little proud. The post are pulled in all the way. As far as I can tell the door just needs to pull in more but it's firmly latched.
Any ideas?
Old Sep 3, 2015 | 11:50 PM
rougeriver's Avatar
rougeriver
I think you may have the post, or striker, adjusted in too far, and the door latch is only catching on it's first detent. Adjust the striker out, and see if when you shut your door it is latching fully, engaging both the initial latching action and then the second, complete closing of the latch on the striker post. It may seem counterintuitive to move the striker out to make the door shut flush, but give it a try.
edit: also, is your new weatherstrip hollow or solid. If solid, it might be exerting a little too much closing resistance coupled with the improperly adjusted striker. The course of action should be the same...adjust the striker out a little.
David
Old Sep 3, 2015 | 11:55 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Is the striker post the type that off sets by rotating it? Is it rotated all the way in?
Old Sep 4, 2015 | 02:43 PM
beartracks's Avatar
beartracks
I'll try losening it and get back to you. You just losen the post and move it around and retighten.
Old Sep 4, 2015 | 03:12 PM
77&79F250's Avatar
77&79F250
Yes, I believe the post is not in the center of the mount plate and just loosening it and rotating it should move it it.
Old Sep 4, 2015 | 04:37 PM
beartracks's Avatar
beartracks
David, you just might be a genius! I feel like a dunce. Anywho, it seems to be working.
note: On the 77 the striker attatches to a captive nut that can move up/down and in/out. You just put it where you want it and tighten it down.
Old Sep 4, 2015 | 08:05 PM
rougeriver's Avatar
rougeriver
Hey beartracks, so glad you got it all worked out. Sometimes adjusting body panels can give me fits, and the only way I knew what the problem was, is that I've done it myself.
David
Old Sep 4, 2015 | 08:49 PM
gumshoe's Avatar
gumshoe
I had the same thing happen to me, I had installed seals from LMC trucks, replaced with ones from DC, now they close with just a push.
Old Sep 5, 2015 | 09:57 AM
beartracks's Avatar
beartracks
I always go with Carpenter first and LMC last. Bronco Graveyard and Macs are also good source.
Old Sep 5, 2015 | 10:02 AM
lafermedavid's Avatar
lafermedavid
good and helpful thread
bradlow
Aerostar
24
Jun 26, 2016 10:36 AM
EP145
Jun 18, 2013 12:53 PM
w5nra
Mar 22, 2012 08:25 PM
cbzdel
Feb 21, 2012 07:02 PM
twinpeaks
Feb 7, 2010 07:55 PM
