Hi, I just installed new door seals and my drivers door will not unlatch with the outside handle when the doors the all the way closed. I tried bending the rod inside the door and it just straightens itself out when I pull on the door handle. The inside door handle opens the door just fine. I figured maybe my seal need too squish down for a little while and it's been about two weeks. If the doors not close all the way it works just fine. Any ideas?
Yes, I could move the striker plate but the door lines up good, and yes the door is harder to close I'm thinking I might need to remove the door seal and install another.
Just move the striker post a little might help it a lot and the door may still line up. Try to adjust before you change seals. If the plastic sleeve is missing on the striker, this will cause the door to be hard to open when adjusted tight.
my passenger door started rattling for no reason a week or two ago, I didn't notice this plastic piece had broke off. I fixed it by putting some aluminum duct tape for sealing home AC vents/ducts around the post. it seems to be holding for now.
