Traction bars.
Old Sep 12, 2015 | 03:28 PM
  #46
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by JOHN2001
Stinkys butt got a kiss in a parking lot
By a Lexus IIRC. Those dam 1%ers think they can get away with anything!
I thought axle wrap was pretty much Sauron and everything else is just orcs. In this application, a longer-the-better set of ladder bars and call it good?
Old Sep 12, 2015 | 04:23 PM
  #47
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by Tugly
A bit more than just a chip...
Bending the driveline, spinning the pinion bearing, damaging the U-joint....
Unless you are driving like a crackhead in a stolen sled pulling truck you have some other issues going on that traction band aids are just masking. I would take them all off and figure it out. Me thinks once you solve the out of spec problem you will not need any extra bars, links , belts, weights, shocks or assorted who ha's to keep your truck from breaking drivetrain parts under normilish driving conditions,
Old Sep 12, 2015 | 04:25 PM
  #48
pirate4x4_camo
Btw tug....nice burnout. On the day I drove my 6.0 to the dealer to turn it in as a lemon law buy back I did a 1/4 mile burnout in mine. It was satisfying. . Yes I power braked for some it at the start... Lol
Old Sep 12, 2015 | 05:07 PM
  #49
hav24wheel's Avatar
hav24wheel
Originally Posted by Stewart_H
Dave, got a pic of your setup?
Stewart
A couple. Non of the top end as of now. here's the axle end.
No bushings on the axle end. Just solid bolts, the frame end doesn't have bushings either. Just a shackle made out of weld on ends from a farm store like these Koch Top Link End Forged Weld-On Ball End Category 1 Not ideal for a street rig prob, but effective. Add bushings at the axle, to help quiet it down if wanted. But idk of mine makes noise. Tires and pipes are too loud. Lol.
It's strong as hell, I've got 42.5 tall tractor tires on it, when I was pulling tree stumps out, I could get the front tires to bob off the ground. Not a superduty, but same axles.... Would be tight fit on a SD
Old Sep 13, 2015 | 04:54 PM
  #50
Tugly's Avatar
Tugly
No power brake above - that's all Stinky's attitude when off the leash. Luckily, I had another FTE member in the passenger seat to "validate" the test.
Corksil - I stared at everything under the truck, with my brain going "suspension" instead of "vibration". The angle of my rear springs caught me off-guard - I thought they were level with the frame. Nope. They are biased high in the rear. I'm still working out the dynamics in my head.
Old Sep 13, 2015 | 05:30 PM
  #51
JOHN2001's Avatar
JOHN2001
Tugly since this has basically turned into your thread I want to point out that you're not making huge power on stock tires. A lot compared to most and you have installed what fixes most people's problem but yet you still have a problem... Something does not add up.
Now I'm going to compare Apple's ro oranges here but think about this. I'm between 100-150 horse power (completely guessing) higher and I'm sure at least that number in tq too. I'm on 35" tires and lifted a bit. I don't have to have ladder bars 99% of the time but insurance on that 1% is money well spent to me.
So I'm lifted with bigger tires a little more power and don't "need" them.
On my SD I needed them due to being on 38x15.5s and an 8" all spring lift.
Old Sep 13, 2015 | 05:36 PM
  #52
corksil's Avatar
corksil
I've been going back in forth in my head about ordering parts and trying to fabricate a traction bar system with a local welder, versus ordering the OUO kit.
The OUO stuff would be the simplest as it would be simple disassembly and reassembly with different components.
Welding something together would be a little bit more risky and have many things that could go wrong.
Old Sep 13, 2015 | 05:39 PM
  #53
JOHN2001's Avatar
JOHN2001
Its all about how good the welder is
In the few sets I've made it would be the same time wise to just buy a set. If you have more skill then money I'd build a set. If not so much time or skill buy a set. It'll work out about the same either way
Old Sep 14, 2015 | 01:21 AM
  #54
pirate4x4_camo
Given how you intend to use them I would say buy a set, I would call OUO and tell tell them what your usage is and see what they have to say. I am sure they have some experience with similar situations and can suggest which one of their setups is going to work best. If you were to order a DIY kit you may end up needed building a few of them before you hit on the best setup. Which is cool because you will then have gained some experience in such matters but being this is your work truck you may be better off working on something other then traction bars
Old Sep 14, 2015 | 01:24 AM
  #55
pirate4x4_camo
I'd say it depends more on understanding the geometry physics. Good welds are not going to overcome a bad setup.
Old Sep 14, 2015 | 05:29 AM
  #56
Tugly's Avatar
Tugly
[LINK]
This one is easy, but I don't like the "slip-grip" (my own expression here) on the axle. It's bad enough when the shocks do that.
I was eyeing this one real hard, but don't forget the cost of buying the square U-bolts.
If you like to weld and want to save some real money, here yuh go:
Old Sep 14, 2015 | 06:07 AM
  #57
JOHN2001's Avatar
JOHN2001
Agreed but with a good setup and bad welds... Well we know the outcome of that.
There's enough information out there to know what works and what doesn't.
Old Sep 14, 2015 | 06:35 AM
  #58
Tugly's Avatar
Tugly
Actually, I wouldn't say so. I did a lot of searches and there are plenty of general discussions... but "specifics" in relation to our suspension is woefully lacking. Every time I think I have a good bead on it, I find something to call my understanding into question... like our tilted springs. I need to figure the angle of the tilt to get an idea where the axle is supposed to be at a given spring suspension.
I see where this will go. I'll need to get a level surface, take measurements of suspension mounts, and predict the movement of the axle. OR... take Stinky to work, drop the front pivot on my traction bars, put a ton in the bed with one of the fork lifts, and measure the natural angles.
Old Sep 14, 2015 | 07:09 AM
  #59
hav24wheel's Avatar
hav24wheel
[LINK]
Hate to say it, but those are essentially adding a radius arm to a leaf spring suspension. It's going to hinder movement. On a street truck, or one that doesn't see a lot of load in the box it will probably be fine, but if you need full of close to full travel, I'd say it's not all that good. To keep axle wrap under control you really only need a single bar if there's room. If not do a dual bar, but still run a shackle at the frame end. It's not overly complicated.
Old Sep 14, 2015 | 07:31 AM
  #60
Tugly's Avatar
Tugly
Originally Posted by hav24wheel
...It's going to hinder movement.....
Now see... this is where I get confused. I look at that design (sticking with the unit with the square U-bolts for this discussion), and it looks sound. I see it as long enough to allow full spring compression - but there is one question that bothers me: Will the front leaf spring mount hit (and bend) the bar at full compression to the bump stops? The rise and fall of the bar at that point will be about half that of the axle, so a simple measurement should answer this - if one knows where the bar will be in relation to the front spring mount.
