Radiator Question - replacement is bigger
Old Sep 13, 2015 | 09:25 AM
hillcountryflt's Avatar
hillcountryflt
Originally Posted by schmiddw
Did this turn out to be a good radiator for you? I have a '67 ford truck and I need a radiator replacement. Could you order it directly from TSM?
I just got the support installed and bolted the radiator to the two holes that work. Will be drilling two more for the drivers side mounting bolts. Pretty sure it will end up working. Quality wise not too impressed with it. Light so that us nice for a one man job. Plastic tank bothers me
Ran the transmission cooler lines and they look like they will work as well. Have not tried matching up radiator hoses yet.
Old Sep 13, 2015 | 02:27 PM
hillcountryflt
Well one more challenge. The radiator fittings for the transmission cooler don't match up with the one from the transmission. Probably going to create a loop to connect the two lines from the transmission for the purpose of getting the engine started.
Old Sep 14, 2015 | 02:33 PM
JEFFFAFA's Avatar
JEFFFAFA
Did you swipe the fittings out of your old rad?
Bob-93021
Feb 1, 2017 12:21 PM
deyomatic
Apr 29, 2009 08:29 AM
55forder
25
Mar 17, 2005 11:46 AM
66sprintw53
May 3, 2004 10:13 PM
55Bubba
Feb 19, 2004 03:49 PM
