Original/Factory information
Old Sep 2, 2015 | 08:12 AM
Millermadness11's Avatar
Millermadness11
I switched cabs 10 years ago on my 51 Ford F1 and now I can't find the patent plate that was mounted on the cab. I'm curious if anyone knows of a way to find out the original color of my truck? I have the VIN but that doesn't give me the information I am looking for.
Old Sep 2, 2015 | 08:18 AM
schoo's Avatar
schoo
My 49's had numbers stamped on the firewall near the center
Old Sep 2, 2015 | 10:00 AM
52 Merc's Avatar
52 Merc
Paint code information is either a stamp on the firewall, or a code letter on the glove box plate for models built after September, 1951. Since you no longer have the original cab, the code will be lost. Do you have any of the original sheet metal; fenders, hood, box, etc? There were limited color choices so a little forensic work should turn up the answers to your question.
Old Sep 2, 2015 | 12:37 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
If you want to know the original color of the replacement cab, it might be contained in a stamp in the cowl. I say it might be because the stamp wasn't there through the entire 1951 run.
Mine is located here, drivers side above the "bulge". The "H" separated from the rest of the code is the color code on mine... Silvertone Gray.
My code reads "RH F4 H 2IH 2272:
RH = Richmond, CA plant
F4 = F4
H = Silvertone Gray
2IH = built August 21 2I = 21, H= August (Jan = A, etc)
2272 = 2,272nd vehicle off the line in August, 1951
rlfocus
Feb 21, 2015 09:09 AM
Izzie1701
Jan 6, 2014 05:26 AM
xcrunner2616
May 6, 2011 01:56 AM
MCarlson
Mar 20, 2008 11:46 AM
watsonm
Jul 28, 2005 11:59 AM
