Cab, door, fender allignment issues
Old Sep 1, 2015 | 09:23 AM
reamer's Avatar
reamer
Hi All
Is the body line from these three supposed the be "linear" or does the fender line supposed to droop down at the grille?
If I make the cab and door (Ford Made) have a beautiful, uniform gap, and then install the "best" keystone aftermarket fenders, to get a uniform gap to the door, the fender bodyline must droop down.
Even then the hood is too high for the fender, YET too low for the cowl.
Now if I raise the fender to it's max travel, I still have to Jack up the core support 2 inches to get a linear body line. (but new the fender pinches the door on top and a big gap on bottom" Suggesting the fender must "droop down")
What is the thickness of an original core support Body mount?
Are mine just compressed too much?
IS the fender body line supposed to "lower, and it heads for the grille?
Old Sep 1, 2015 | 10:57 AM
Franklin2's Avatar
Franklin2
I would not go by the look of the body line and whether it's level or not. Go by the gaps at the front of the door and around the hood. Make sure the body line at the back of the fender matches the body line in front of the door.
As far as shims under the core support, I would be careful and look at the fan shroud. Too low and the fan will hit the top of the shroud, too high the bottom of the shroud.
Old Sep 1, 2015 | 12:17 PM
reamer's Avatar
reamer
Thanks Dave!
SCFlareside
Jan 20, 2016 08:08 PM
7636074460
Jan 14, 2013 08:00 AM
stallion3599
Feb 5, 2012 09:30 AM
73 ford guy
17
Feb 26, 2008 11:41 PM
gr8dain
1978 - 1996 Big Bronco
Jul 24, 2003 11:14 PM
