EGR Delete.............No code??
Old Sep 1, 2015 | 08:26 AM
darrellbarnes's Avatar
darrellbarnes
I'm not complaining. Have a February build '05. I just installed the River City EGR bypass and expected that there would be a code. I did not pull the EGR valve. Am I just lucky. Guess I should pull the EGR and clean just to see how much fun it is but figured that it's harmless now with the delete. No real noticeable change in the way the truck runs either.
Old Sep 1, 2015 | 08:36 AM
dannyboy950's Avatar
dannyboy950
Slightly confused here. You did a EGR Cooler bypass? EGR valve itself is still inplace?
Or am I missreading something?
Old Sep 1, 2015 | 09:04 AM
jswartz84's Avatar
jswartz84
Mines also a February 2005 build and it does not throw a code either.
Old Sep 1, 2015 | 09:52 AM
darrellbarnes
Okay, EGR delete. Sorry for the confusion. Is the EGR valve normally just left in place or is it necessary to pull the valve and install the block off plate?
Old Sep 1, 2015 | 09:55 AM
mhoefer's Avatar
mhoefer
Either way, block off plate with EGr valve on top plugged in, or in the intake with it plugged in. You have to use a tuner to properly delete the EGR or the computer won't run the fan properly and other things.
Old Sep 1, 2015 | 09:56 AM
jswartz84's Avatar
jswartz84
Either way is fine. I prefer to leave it in the original hole so I don't have to leave it laying somewhere in there.
Old Sep 1, 2015 | 09:57 AM
jswartz84's Avatar
jswartz84
No tuner is necessary if you leave the valve plugged in. The tuner is only needed to turn off the CEL.
Old Sep 1, 2015 | 10:15 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
My 2006 is an October 2005 build with the VXCF4 flash (updated to Buzz FICM flash in January 2006) and never threw a CEL for an EGR Delete.
Josh
Old Sep 1, 2015 | 11:43 AM
05F250DSL's Avatar
05F250DSL
While my 05' does not throw CEL if you put a scanner on it it has codes for low egr flow, and egr performance.
Old Sep 1, 2015 | 02:36 PM
Thor'sHammer's Avatar
Thor'sHammer
'05 here. I have an egr cooler delete with the egr valve installed. No codes, no pending codes and all has been well ever since I installed it.
ben158
Nov 20, 2014 11:58 AM
propellerhead
1983 - 2012 Ranger & B-Series
Jun 14, 2013 08:14 PM
chrisbraziel
Sep 20, 2010 08:22 PM
MikeB 88
Aug 4, 2010 06:13 PM
signtist00
2004 - 2008 F150
Aug 25, 2008 09:15 AM
