4R100 no drive
Old Aug 29, 2015 | 06:01 AM
hienergy557's Avatar
hienergy557
4R100 no drive
Driving along today my trans started doing some weird stuff. It lost all gears. Forward and reverse.
If I turned the truck off and let it sit a while it would go again for awhile then loose drive again.
When I got home I checked fluid level and did KOEO o/d off and back on.
I drove it around the block and it seemed ok, so I went on my way.
After about 20 min I noticed the OD light flashing.
I checked codes and It had P1754-ccs.
Any suggestions?
Cheers Colin
Old Aug 29, 2015 | 07:51 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
P1754 Coast Clutch Solenoid Circuit Malfunction
It would "appear" you have a bad CCS or a wiring problem. Check ALL wiring & FUSES thoroughly! On my 02 the fuse for it is 23.
Old Aug 29, 2015 | 08:23 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No matter what the coast clutch solenoid is doing it won't cause a no drive/reverse. I'm guessing you are very low on ATF.
Old Aug 29, 2015 | 06:04 PM
hienergy557
Mark,
I checked the fluid level and it's fine. It's seems to be driving fine now, I serviced the trans 15,000 km ago(approx 9000 miles) run flush, new filter and oil.
Can the other solenoids in the pack cause no drive?
My question is, CCS solenoid is one in the solenoid pack. If I have to replace the pack, I'm going to have to get it from the US.
We had the 7.3/4r100 up until 2006 here in Australia. If I send my VIN to a US supplier they don't work.
So how do I know which one I need. Any way to identify them?
Cheers Colin
Old Aug 29, 2015 | 07:59 PM
Mark Kovalsky
The solenoids can't cause that. It could be loose feed bolts under the valve body, or there has been a mechanical failure inside the trans.
Old Aug 29, 2015 | 09:13 PM
hienergy557
Is that a common thing? Is their anything else I need to check before pulling the pan?
Old Aug 29, 2015 | 10:05 PM
Whitey Ford
Did you check fuses? Does the solenoid pack have power? Why not try and solve the code issue.
Old Aug 29, 2015 | 10:49 PM
hienergy557
I've checked fuses, unfortunately none are blown. I'll check the connections on the trans next.
Old Aug 30, 2015 | 06:18 AM
Whitey Ford
https://www.ford-trucks.com/forums/1...low-power.html
Old Aug 30, 2015 | 09:17 AM
Mark Kovalsky
No, there is not. It is something non-electronic inside the trans.
Because that is a waste of time. That code is NOT causing this problem.
That's not the problem, but the time is yours to waste.
Old Aug 30, 2015 | 09:19 AM
Mark Kovalsky
That's out of left field. Other than it is also a trans issue it has nothing in common with this problem.
Old Aug 30, 2015 | 01:10 PM
Whitey Ford
That thread, like others, make it appear that power to the solenoid pack is relevant to forward and reverse movement of the transmission. It also seems to suggest that electrical issues can mimic mechanical failure.
Old Aug 30, 2015 | 01:12 PM
countrycar's Avatar
countrycar
Back in 2010 I had this very same thing happen to me. I was driving at about 5 mph on a dirt road and my truck went into a neutral position. I thought I had accidently hit the gear selector into neutral, but no. I ended up having to have it towed to a trans shop. After tearing down the entire trans and finding nothing wrong, they figured that it had to be in the TC. I sent it back to the guy that built it for me, Rusty at TCS. Again, nothing wrong here either, it was in perfect condition as well. The trans shop put it back together and it worked fine and it's worked fine ever since. I never figured out what the heck happened either. The trans shop was a very reputable heavy/race trans builder who really knew his stuff. But again it would not move no matter what I tried. They even checked the transfer case as well, thinking maybe it had gotten stuck or jumped between 2 and 4 wheel drive, or that maybe it was broke. Nothing.. As far as I know we are the only 2 people that have had this issue..
Old Aug 30, 2015 | 03:30 PM
Mark Kovalsky
No, it did not. That truck did move forward and reverse. It was stuck in fourth gear. This thread is about no engagement at all. Totally different problems.
No forward or reverse CANNOT be caused by ANY electrical problem.
Old Aug 30, 2015 | 04:15 PM
hienergy557
Update
I checked Fluid level- fine
Checked fuses - none blown
Then I pulled the connector going to the trans for inspection and checked for power there- all good.
I then put the connector back on and made sure it seated properly.
I went for a 1/2 hour drive on Sunday and no codes, drove to work this morning and no codes.
The connector looks a little dodgey so I will get a new one of those but it seems it may have been the problem.
Hope the problem doesn't come back. I'll update if it does.
Cheers Colin
Fordbert
Dec 12, 2018 07:37 AM
DZL JIM
Jun 25, 2014 10:48 PM
Dorman
Jun 20, 2010 04:04 PM
scotterdaddy
Apr 29, 2007 07:41 PM
kb1aah
Mar 17, 2006 03:01 AM
