transmission problem
Old Apr 22, 2007 | 11:42 AM
scotterdaddy's Avatar
scotterdaddy
2001 F250 SD AT
put the transmission in reverse then switched to drive transmission wouldn't shift up, didn't matter where the gear indicator was, drove 7 miles turned it off, no reverse, transmission fluid was fine, no odor, temperature was okay, didn't overheat, overdrive light was flashing, what's up?
Old Apr 22, 2007 | 11:44 AM
nightskyisme's Avatar
nightskyisme
Get it scanned, there are stored codes pertaining to the transmission issues you are having.
Old Apr 29, 2007 | 06:36 PM
scotterdaddy
Transmission Problems no reverse no neutral
dtc p0603 internal control mod kam error. disconnected both neg batt cables to reset any dtcs, still no reverse/or neutral. 30mph top speed wont upshift doesnt feel like its slipping. inspected didntfind any leaks, removed pan and inspected normal amount of friction material no chunks etc. fluid clean. visually inspected didnt see anything wrong with the valve body. with the scanner looked at datastream didnt see anything wrong the trans range etc seems to be working. is this a common problem? i think i need a transmission expert to give me some advice. i dont think the trans needs replace. something wrong with the valvebody? forward clutch stuck? reverse clutch not appling? i dont know
Old Apr 29, 2007 | 07:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Call up Brian at BTS, tomorrow sometime and tell him your problems. Tell him the guys on FTE sent you. Even though he probably won't sell you anything, he will take time out of his day to help out people, that is how he is.
870-422-3673.
