LCF Shifter
Old Aug 27, 2015 | 07:39 AM
GloveGuy's Avatar
GloveGuy
Smile LCF Shifter
Hi there,
I just got my 2007 Ford LCF back from the dealership yesterday. It was in for top-end engine work and the engine seems to be purring along nicely, once again.
This truck has the 5-speed "Torqueshift" transmission and it was performing beautifully before the truck was towed in for repair. Although the transmission is still performing well, the actual gear shifter seems to be stiff to operate, where it was smooth as silk before the engine was pulled for repair. BTW, the transmission was left in the truck.
The shifter slides pretty well from Park to Reverse, and not bad from Reverse to Drive, but it progressively gets harder to slide as you move down through the gears. I haven't even taken it to its lowest point because I don't want to force anything.
My question is, is the shifter assembly attached to the transmission via a cable, or linkage that the Ford tech somehow installed, or adjusted incorrectly?
I know these trucks are a bit of an odd-ball and since there not common, perhaps the tech hooked it back up incorrectly. He's got over 25 years as a Ford diesel mechanic and said this was the first LCF he had pulled the engine on.
I've got an email into their service department, too, but I thought I'd check here, as well, since there are so many great people on here that have given me good advice in the past.
Thanks for the time. I look forward to hearing from anyone with any thoughts.
Old Aug 27, 2015 | 01:55 PM
stuart1's Avatar
stuart1
Don't even bother asking here. Contact the service department.
Old Aug 28, 2015 | 10:26 AM
GloveGuy's Avatar
GloveGuy
My goal is to simply cross-reference information and gain a little information as to how the system works with reference to shifter cable/linkage.
I rarely trust dealerships, especially the one I've been forced to deal with, but that's a story for another time and place.
Thank you for the reply, though.
Hillbillysuv
Large Truck
Sep 8, 2018 05:28 PM
greentruck72
Aug 27, 2016 10:15 PM
graymule
Jul 12, 2010 05:21 AM
scrapyardking
Mar 17, 2008 11:19 PM
