Brake Booster?
Old Aug 24, 2015 | 06:29 PM
lmayer460's Avatar
lmayer460
Brake Booster?
1978 F-150 Custom 4x4
Thinkin I have a problem with the brake booster, here are the symptoms:
When driving the brakes work fine on the first pump, but when released and pumped the second time they are stiff and about 50% braking power. This condition persists if i continue to pump the brakes, but if I continue driving without braking they return to normal in a short period of time and It will feel fine again only on the first pump...almost like its taking several minutes for the vacuum to build up in the booster.
No recent work on the brake system has been done and the fluid level looks good. I'm going to inspect the check valve and the vacuum line tonight after work....any other thoughts?
Old Aug 24, 2015 | 06:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That sounds more like a restriction in the vacuum line than a problem with the booster. Make sure the line isn't collapsing or hasn't deteriorated inside.
Old Aug 24, 2015 | 08:10 PM
Blue and White's Avatar
Blue and White
I think you are on the right track checking the line and valve. My OE check valve cracked and leaked. Replacements are usually in stock in the "Help" section at the AP store.
davidrozeboom1
May 14, 2017 03:16 PM
BAMAJiPS
May 6, 2016 09:10 PM
Thunderhorn
1978 - 1996 Big Bronco
Apr 10, 2016 04:13 PM
EliteScapes
32
Apr 18, 2011 10:59 PM
bigfoot22
Aug 13, 2010 09:10 AM
