Brake experts needed
Old May 13, 2017 | 06:59 PM
davidrozeboom1's Avatar
davidrozeboom1
i have a 1973 F350 SCS. Was driving fine for the first time in a year, then I had little to no brakes all of a sudden. That and I can hear a hissing sound when the pedal is depressed. Think it's the brake booster/master cylinder, but seeing if anyone else has ideas. Haven't checked anything out yet to see if I can see busted hoses or wetness at the drums yet
Old May 13, 2017 | 07:05 PM
Filthy Beast's Avatar
Filthy Beast
Yeupp....vacuum lines going to the booster, the booster itself, and/or the check valve on it.
Check the vacuum lines and check valve first....if they check out ok there's other tests for the booster itself.
Hope that hissing sound isn't brake fluid leaking......
Old May 13, 2017 | 07:56 PM
PapaBearYuma's Avatar
PapaBearYuma
If you can hear it from inside the cab, I don't think it's fluid-I think it's vacuum. Probably inside the booster
But the vacuum hose and check valve are easy to check...
Old May 14, 2017 | 02:06 AM
Ozzie H.'s Avatar
Ozzie H.
I agree that the hissing sound is likely due to something with the power brake booster, however it surprises me a bit that it would result in "little to no brakes". Perhaps there is more than one problem.
Old May 14, 2017 | 08:52 AM
davidrozeboom1
Well around me a brake booster is around 100, brake booster with master cylinder is like 120, so I might as well replace both. The master cylinder on there now looks horrible
Old May 14, 2017 | 10:18 AM
Filthy Beast
I know you know to bench fart the MC before installing....but had to say it
Old May 14, 2017 | 01:58 PM
PapaBearYuma
When installing the new booster, make sure the rod that engages it has the proper clearance. I've not done one yet, but that seems to be the cause of many frustrations here...
Old May 14, 2017 | 03:16 PM
meangreen92's Avatar
meangreen92
Might have to do the lines between the booster and the metering/proportioning valve, but no biggie. I bought five or six footers and cut and reflared in order to install the original line fittings. Wrapped them around an aerosol can to make some 'stress-absorbing' coils, and plumbed them in.
And in case you're not familiar, there's also the valve on the metering/proportioning valve, which needs pulled out on lighter trucks, in order to bleed the fronts. On heavier GVW trucks like an F250, that little valve gets pushed in to bleed the fronts.
cwesner227
1983 - 2012 Ranger & B-Series
Sep 9, 2014 12:55 PM
muckypaws
1978 - 1996 Big Bronco
Apr 16, 2009 11:59 PM
LTCPipkin
Aerostar
Oct 28, 2007 08:56 PM
Hellbore
May 27, 2006 01:02 AM
Gary-R
Aug 9, 2005 04:55 PM
