Sponsored by: Auxito
Transmission woes
Old Aug 23, 2015 | 11:00 PM
shempwalker's Avatar
shempwalker
Transmission woes
-My pickup was parked and hit in the rear axle in January. I had to have the whole axle replaced as well as the leaf spring to frame mounts.
-I finally received the pickup back and now when the trans is in Drive it will not up-shift until the rpms reach 2500 and it is a hard shift.
-Also the speedo does not work now.
-Check engine light also came on with code P0500- vehicle speed sensor.
-I replaced the VSS at the transfercase and the ABS sensor in the rear differential with no change.
-Please help.
Thanks in advance
Old Aug 24, 2015 | 02:10 AM
bc11's Avatar
bc11
I think you need to go back to the shop and also contact the insurance adjuster as there appears to be more damage than they estimated.
Old Aug 24, 2015 | 09:08 AM
shempwalker
The insurance totaled the truck but I wanted to keep it. My buddy's friend replaced the rear end for me.
-Does it seem more electrical than a mechanical issue?
--I wonder if the drive shaft was pushed deep into the T-case and misaligned something.
-I did note the VSS gear was pushed back onto the VSS a bit when i removed it.
Old Aug 24, 2015 | 10:13 PM
shempwalker
Checked the voltage at the ABS sensor and Transfer case VSS connectors.
-ABS- 5 volts even with ignition off.
-VSS- no voltage with ignition off and on.
-Wiring harness?
Thanks, SW
Old Aug 25, 2015 | 12:05 AM
Bluegrass 7's Avatar
Bluegrass 7
The VSS does not have any voltage supply.
It produces a voltage who's level and frequency is developed according to rotation speed of the teeth passing by the sensor..
Vehicle Speed Sensor!. VSS.
Good luck.
Old Aug 25, 2015 | 12:09 AM
shempwalker
So I can spin the old VSS and see if it puts out voltage?
-I am suspecting the inside of the t-case has a problem since the truck was hit in the rear axle so hard.
-Whatever drives the VSS in the T-case may be off kilter
Old Aug 27, 2015 | 12:52 AM
shempwalker
Just checked the VSS on a drill and it puts out voltage.
-Does anyone have a T-case breakdown?
Thanks, SW
Old Sep 1, 2015 | 09:30 PM
toby tough's Avatar
toby tough
My 92 did similar to yours and it was the connector to the VSS. All I had to do was wiggle it a bit and it was fine. Could be you have an issue with that connector or wiring for it.
Old Sep 1, 2015 | 10:41 PM
shempwalker
I finally got it. I replaced the broken speedo drive gear, but did not have a good picture and being under the truck I did not see the clip that keeps the gear from backing out. I talked with Ken at A & A transmissions in Stockton (he is a beast with manual transmissions/Transfer-cases) and he was exactly correct so am good to go now.
-I appreciate all the input/guidance.
66F100Again
Jun 24, 2024 12:46 PM
TreasureHunter
Apr 2, 2013 04:29 PM
MYFORD250
20
Sep 28, 2012 07:02 AM
atvmech1
May 28, 2007 10:53 PM
