High Fuel Pressure
Old Aug 22, 2015 | 08:54 PM
pminne's Avatar
pminne
Rocky Mountain High
Question High Fuel Pressure
Need some help here with a high fuel pressure indication. My Isspro Performax EV2 fuel gauge shows nearly pegged at 100 all the time. It used to show between 60-70 or so, but for the past several weeks, it shows full on pressure. Truck starts and runs fine, all temps and other indicators are all normal at all speeds, towing, etc. Bad gauge? Bad sensor? 7th fetzer valve going?
Lastly, is there anything wrong with running high fuel pressure if the gauge and sensor are working properly?
Old Aug 22, 2015 | 09:10 PM
F350-6's Avatar
F350-6
My experience has been if the fuel pressure goes over 100 psi the pump cuts off momentarily and then comes back on. Leading to a viscous cycling of the pump. My guess is you've got a gauge/sending unit issue.
Must be in the air. My gauge will now read 0.4 psi under hard acceleration. (digital gauge) Since there is no seat of the pants difference on my end, I've either got some incredible tuning, or a bad sending unit. (reads 75 while cruising)
I've had a really dirty pre-pump filter before and know the truck won't get out of it's own way below 20 psi, so I'm guessing I don't really have 0.4 psi.
Old Aug 23, 2015 | 09:28 AM
Thomas White's Avatar
Thomas White
I would look for an issue on the ground side of the wiring or the sender may be kaput. Easy to confirm with a Fuel Pressure Test.
High Fuel Pressure will lead to premature O-Ring, Seal, and Pump Failure. According to "The Book", 80 / 65 psig is max for static and residual pressures respectfully. The pump NEEDS to move fuel to cool itself.
Old Aug 23, 2015 | 10:56 AM
Tugly's Avatar
Tugly
Ahem.... I have also seen something similar without a bad sensor.
  1. Is the sensor on the passenger side of the fuel bowl, or in the other port?
  2. If on the other port, how many miles on your fuel filter? Was this immediately after a fill-up?
Old Aug 23, 2015 | 11:12 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I have the same gage and it is doing the same thing. When you turn the truck off does it go to zero? If it's like mine it will not go to zero with the key off. I was told the sending unit is bad.
Old Aug 23, 2015 | 03:35 PM
pminne's Avatar
pminne
Rocky Mountain High
Thanks all for the replies. It does not return to zero after shutdown. I can't recall the location of the sender, it's been a few years since I installed it. I can take a look. Why would location matter??? It worked at one point.
My fuel filter is likely due, I will change that out soon. I don't recall that this occurred after a fuel up. I was just driving and noticed it was high and it has been there ever since (many hundreds of miles ago).
Old Aug 23, 2015 | 04:11 PM
Crewcab Turbo
I just checked my gage with the truck off. It only goes down to aprox 42.5 lbs. I wonder if it's actually the gage itself that's bad and not the sender? If the sender was bad wouldn't the gage go down to zero when the truck is off??
Old Aug 23, 2015 | 06:23 PM
F350-6's Avatar
F350-6
My fuel filter is likely due, I will change that out soon.......
Because a sending unit located post filter could just be reading low pressure due to a plugged filter. If that were the problem, changing the filter would fix everything.
Usually it's the sender when that happens.
Old Aug 24, 2015 | 09:27 AM
pminne's Avatar
pminne
Rocky Mountain High
OK, got a fuel filter on order, will post with an update in a few days or so...thanks again guys!
Old Aug 24, 2015 | 04:52 PM
pminne's Avatar
pminne
Rocky Mountain High
UPDATE: so today the gauge just started to read about 85 and stayed there. Drops a bit when accelerating, so it seems to be working. Is it a bad sender? Thoughts???
Old Aug 24, 2015 | 10:36 PM
Tugly's Avatar
Tugly
Very likely a bad sensor - it's common, though I haven't experienced it yet.
Old Sep 8, 2015 | 02:29 PM
pminne's Avatar
pminne
Rocky Mountain High
UPDATE: it ended up being the sensor. Thanks all!
Old Sep 8, 2015 | 02:46 PM
jhl3's Avatar
jhl3
Does it return to zero now when you switch the truck off?
If it doesn't, I have found that that is an indication of having air in the fuel line somewhere.
Old Sep 8, 2015 | 02:50 PM
pminne's Avatar
pminne
Rocky Mountain High
It does not, but never has either.
Old Sep 8, 2015 | 03:15 PM
scotttahoe's Avatar
scotttahoe
I don't recall mine ever going to zero either. Shut truck off would stay at the point at idle pressure. Turn key on gauge resets to zero and goes to KOEO pressure. My sender just went before I pulled the motor. Called Isspro and got new sender and a snubber to help with the vibration. It's the vibration in the motor that kills these sending units. (along W/others)
1994F2507.3L
Oct 14, 2016 03:58 PM
Macrobb
Jan 21, 2012 11:24 PM
Sheryle
Feb 28, 2011 04:39 AM
gmc28
Nov 18, 2010 08:09 AM
screech.owl
Mar 15, 2009 07:22 AM
