300 4 barrel conversion?
Old Aug 22, 2015 | 06:09 PM
cloudflare's Avatar
cloudflare
He all, ive been having trouble with my stock intake and carb set up so I've been contemplating switching my 66 300 over to a 4 barrel setup. Has anyone here done something similar? My plan is to use the Offenhauser Dual Port Intake Manifold. headman duel headers and a Edelbrock Thunder Series 500 cfm carb. Is this a good idea?
Old Aug 22, 2015 | 06:34 PM
85e150's Avatar
85e150
Great idea. Believe it or not, you are not alone:
https://www.ford-trucks.com/forums/1...swap-help.html
And billions more 4bbl, header, EFI manifold swap, ignition and exhaust threads in that forum.
Old Aug 23, 2015 | 12:08 PM
daveengelson's Avatar
daveengelson
Not an authority by no means, and do not intend being a nay sayer, but you may want to review the trans/axle gearing to determine if they meet 4bbl application. Wonder if you will need to upgrade the Cam and Lifter's for the 4bbl application? Having gone from a 2bbl to a 4bbl on my 65 F100, with Dana 44, 3.54 axle ratio, and T18, I rarely, if ever, get the Holley into the secondaries. Anyhow, just wondering, perhaps more knowledgeable member can advise?
Old Aug 23, 2015 | 01:24 PM
1972RedNeck's Avatar
1972RedNeck
You don't need a new cam by any means but a new cam would help let more air in and out which is the whole point of the carb and header swap.
FirstFord1994
31
Mar 24, 2023 02:22 PM
jrayyy
Feb 27, 2013 12:18 AM
lsendel
Jun 2, 2004 06:16 PM
szepj1
Oct 24, 2003 01:43 AM
osborn_1
May 28, 2003 08:58 PM
